Author Topic: Greasing up cb750  (Read 789 times)
tangylee
Greasing up cb750
« on: October 11, 2011, 09:02:08 AM »
I recently got a new 1982 cb750f and am going to attempt to grease up some main parts, mainly the wheel bearings...
any advice to doing this? about all i know is i need a grease gun...
Re: Greasing up cb750
« Reply #1 on: October 11, 2011, 09:06:27 AM »
An 82 is a D(ual)OHC. This is a S(ingle)OHC site. The SOHCs stopped in 1978 (except for the 650) You may want to post in the "Other Bikes" forum or in the DOHC Owners group.
Though someone here may still be able to help.
Offline CycleRanger
  • No comment about being an
« Reply #2 on: October 11, 2011, 09:06:48 AM »
Howdy!  You're probably going to get more constructive feedback from this forum: http://www.cb750c.com/
The original bearings on the earlier bikes were only sealed on one side and could, in theory, be repacked but to do it properly the bearings must be removed which usually damages them.
I don't know if the DOHC's used the same bearings. If the DOHC used bearings that are sealed on both sides they aren't serviceable anyway.
Ideally you are going to want to replace the original bearings with new bearings that are sealed on both sides.
You can probably do both wheels for less than $50.
All Balls sells complete kits, they can probably fix you up.
http://www.allballsracing.com/
It's good that you are looking at the wheel bearings, I think a lot of folks overlook wheel bearings when they're servicing or resurrecting an older bike.
New wheel bearings are one of cheapest and most important things you can do to make sure the bike is safe.
« Last Edit: October 11, 2011, 10:49:02 AM by CycleRanger »
