Author Topic: Question about carb rebuild kit  (Read 1834 times)
Offline jabs83
« on: October 12, 2011, 04:54:59 PM »
I ordered a carb rebuild kit to replace a faulty float valve on my 73 cb750. The kit I ordered is made by K&L. Inside the kit is are the prepackaged air/fuel screw and spring. In that prepackage is a an O-ring, and a washer. Can someone please tell me where the washer and the o-ring belong in relation to my carbs?
I pulled apart my carbs, but don't see any parts similar to the o-ring and the washer in the kit?
Offline nancy
  • CB750 K2'ish - SOLD!! Triumph Sprint GT2011
  • No worries matey..
Re: Question about carb rebuild kit
« Reply #1 on: October 12, 2011, 05:06:01 PM »
The only place I can think of for an o-ring, is on the fuel connecting pipe between the carbs on the rack.
Offline tlbranth
« Reply #2 on: October 12, 2011, 05:40:27 PM »
Can't you look on a parts fiche to see what goes where?
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Johnny5
    • CB350F build thread
« Reply #3 on: October 12, 2011, 06:27:22 PM »
Im pretty sure there's an oring behind the small washer and spring for the air screw. Get a flashlight and look in there.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline Kermit
« Reply #4 on: October 12, 2011, 06:33:47 PM »
sometimes they will have kits that are for multiple bikes and not all bikes will require all the parts. Its just easier to add the o ring to all the kits even if you won't need them.
Offline jabs83
« Reply #5 on: October 12, 2011, 06:52:19 PM »
I looked at a parts fiche, buts I can't really make out where they go. The air mix screws I pulled out of my carbs didn't have washers, or o-rings.
Do the sync plugs have washers, as only one of my carbs' sync plugs had a washer?
Offline greenjeans
  • 1972 CB750K2
« Reply #6 on: October 13, 2011, 05:19:56 AM »
If they are the small washers, they go on the screws that you use to synch the carbs.
The screw with the spring doesn't use a washer or o-ring.
O-ring is likely for the bowl drain screw or for the "T" fitting between the carbs ?
Offline david 750f
  • 1976 CB750F
« Reply #7 on: October 13, 2011, 09:36:47 AM »
If you have 8 O-rings they are for the fuel T fittings.
If the package has 4 O-rings they should be for the float bowl drain screws.
The small flat washers are for the carb sync ports.
« Last Edit: October 13, 2011, 01:33:30 PM by david 750F »
1976 CB 750F
« Reply #8 on: October 13, 2011, 12:47:53 PM »
I had them in my kit too - and left them out.  I couldn't find any place they would fit.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #9 on: October 13, 2011, 01:33:48 PM »
o-ring for the float bowl drain screw?
Offline lrutt
« Reply #10 on: October 14, 2011, 04:31:33 AM »
Those washers and o rings are in those holes for the air screws. They generally are a tight fit into the carb body and can at times take some effort to remove. O ring in first, then washer so the spring rides on that. Your choice to try and dig that out or leave it.
I've noticed that often times they can come out when blowing compressed air through carbs.
They are in there though, you can be assured of that.
« Reply #11 on: October 14, 2011, 04:55:35 AM »
it must be different by year, those o-rings I had would never fit in the air screw hole.
