Author Topic: Carb problems cb650  (Read 6381 times)
Offline nate sere
Re: Carb problems cb650
« Reply #25 on: October 20, 2011, 10:31:07 PM »
I traded the 650 carbs for the 750 carbs so thats not a choice.  I need to figure these out.   I am running pods, open headers, and keihnin 750 carbs.  We put 110 jets and advanced the timing and it helped, but its still not right.
I was thinking about dropping down to 102.5 jets.   I am looking into getting some type of muffler but hate to alter the look of the bike.   Its exactly what I want right now.....
The stock 650 carbs came with 90's I believe.  ???   Will the 102.5's help?
Offline Pinhead
  • 1979 CB652-ST
« Reply #26 on: October 21, 2011, 12:21:55 AM »
With pods? The 650's carbs are a cast-iron #$%* to tune since you can't raise the needles or change the idle jets. The 750 carbs are a bit more tunable.
In my '79 with the stock airbox I run 102.5's since I removed the air filter cover. With just pods you'd probably have to go much larger than that. I believe a member with the 650's PD carbs went all the way up to 120 mains but I could be mistaken. I'm sure there's a thread or two out there with regards to the 650 and pods...
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline nate sere
« Reply #27 on: October 21, 2011, 12:34:16 AM »
but im using 750 carbs now.   is that what you are using?
Offline phil71
« Reply #28 on: October 21, 2011, 01:05:29 AM »
you're on your own bro. You've introduced so many random elements here, that nothing any of us say is anything more that speculation. Keep dicking with it till it runs okay, and eventually it will. but nothing we say matters at this point... you have a one of a kind, and tuning is your problem now.
Offline nate sere
« Reply #29 on: October 21, 2011, 01:36:23 AM »
so i'm the only person on this board who owns a cb650 custom, with pods and 4-1 open pipes who is using cb750 carbs?
Offline trueblue
« Reply #30 on: October 21, 2011, 05:40:52 AM »
You are the first I have heard of, but I can't be certain
1979 CB650Z
« Reply #31 on: October 21, 2011, 02:48:28 PM »
You aren't really listening to people that know mate, that combination is going to be extremely hard to get even close to running well.....
750 carbs hate pods at the best of times and it is well documented here, add in those pipes and you are going to spend a lot of frustrating hours trying to get it right......    Good luck
Offline scunny
  • don't call me expert
« Reply #32 on: October 21, 2011, 03:50:52 PM »
nothing wrong with tinkering Mick. anything is possible nate. you are sure giving yourself an uphill battle tho.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
« Reply #33 on: October 21, 2011, 03:55:26 PM »
I am a born tinkerer mate, but some things just make life a lot harder.....
Offline Pinhead
  • 1979 CB652-ST
« Reply #34 on: October 21, 2011, 05:39:49 PM »
Nope, I have no experience with that Carb combination so I'll probably be of no help at this point.
Doug
:D
Offline nate sere
« Reply #35 on: October 25, 2011, 06:38:30 PM »
I thought that I was getting too much fuel from the CB750 so I went down from 110 to 102.5 and it was much worse.   I went the other way and went to 120's and it ran like a whole new bike.  Pulled very hard all the way through the rpm band.  Slight hesitation on very bottom end and very top end.   I am going to try 125's tomorrow just to see if it makes any difference, but I am pretty sure that the 120's are going to be the best solution.
Offline phil71
« Reply #36 on: October 26, 2011, 01:59:05 AM »
are those numbers honda, or dynajet? that hesitation out of the hole is probably the vast mismatch when the pilot jets hand off to the mains. At least you're getting closer.
125s seem awfully big for a 650 with no internal mods tho.
Offline nate sere
« Reply #37 on: October 26, 2011, 02:26:57 AM »
no known internal mods.
It was really fast and pulled the front tire a little in 1st.
