Author Topic: Starter button spring.  (Read 900 times)
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
« on: October 13, 2011, 03:03:40 PM »
My starter buttun spring doesn't seem to be so springy anymore. Where would one go about finding a replacement spring?
Lowes, Menards, and local auto shops don'tseem to have anything close to that size.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: Starter button spring.
« Reply #1 on: October 13, 2011, 03:18:09 PM »
Hardware store?
Offline becken
« Reply #2 on: October 13, 2011, 03:29:03 PM »
Try a gunsmith.
1976 CB550F bought new
1981 CM400A wife bought new
2004 GL1800
Offline stidds
« Reply #3 on: October 13, 2011, 03:29:12 PM »
When I lost the spring from my starter (I know what an idiot, LOL).  I actually used a spring from a click top pen, I found one the correct diameter and cut it down with some pliers.
Offline DavePhipps
« Reply #4 on: October 13, 2011, 03:32:19 PM »
Harware stores were a bust and I don't think there are any gunsmiths around here
OOOOOOO I like that one. Very Mcgeyver.
Thankfully I have many dead pens.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline jonboycox
« Reply #5 on: October 13, 2011, 04:59:11 PM »
Hi, I just rebuilt my starter button on a CB 400F using the starter button assembly from an old Goldwing. I reused the guts from my switch and put them in the still intact plastic housing from the Goldwing. Suffice to say that I have the spring from the Goldwing start button if you really need it. It would need to be a pretty stiff pen spring to have any kind of longevity. The other spring I think that would work would be from spring loaded punch used for marking points in metal and wood work. You can buy them at Home Depot, It is the size of a pen with a steel point on the end and you push down on it and it "pops" leaving a mark in whatever material you are marking. I've had one apart and the spring is pretty stiff and probably just the right diameter. You could cut it to length with side cutters easily.
« Reply #6 on: October 14, 2011, 06:21:22 AM »
35318-259-000 as long as its the start button only NOT the headlight off/start button
« Reply #7 on: October 14, 2011, 07:50:11 AM »
I lost mine in some horse #$%* - true story, it flew under the barn and that was it.  After that I switched to R6 controls.
