Author Topic: Where to get sprockets for old Hondas?  (Read 2118 times)
Offline catzor
« on: October 13, 2011, 06:15:09 PM »
I've got a 73 cb175 that I need sprockets for, but I don't know where to look online for aftermarket sprockets. Anyone know if most/all Hondas use the same bolt pattern? I can order OEM if need be, but the prices are a little ridiculous.
1991 CB250 Nighthawk
1986 VT500C
1989 EX500
1973 CB175 Super Sport
Offline Coyote13
Re: Where to get sprockets for old Hondas?
« Reply #1 on: October 13, 2011, 07:20:38 PM »
Check Renthal
'78 CB750K.  Throttle ripper.
'71 CB100.  Grocery getter.
'01 XL883.  Panty dropper. Gone but not forgotten.
Offline Doum
« Reply #2 on: October 13, 2011, 08:31:45 PM »
All motorcycle dealer/shop will be able the order the sprocket you need.....
Offline johnny
« Reply #3 on: October 14, 2011, 03:10:07 AM »
1976 CB550K
1974 CB350F http://forums.sohc4.net/index.php?topic=81781.0
1974 CB550K
1972 CB350 Twin
1965 Lambretta
196(?) Honda S90
1975 Ford Bronco
Offline kirkn
« Reply #4 on: October 14, 2011, 08:10:26 AM »
Dennis Kirk, Bike Bandit, SprocketSpecialists, ebay, MotorcycleSuperstore, J.C.Whitney
Someone'll have what you need at a decent price.
Offline faux fiddy
  • bike in a box
« Reply #5 on: November 05, 2011, 02:22:14 AM »
This may be the place to ask. Or keep up the flea-bay searching.
I've got a few or maybe just two old/new sprockets around. I think they might be for a 350 twin, but similar enough to 350f if not the same, maybe they are adaptable to anything.  They are NOS with no wear and no indication they have ever been installed. Not sure how many teeth, both [of the three ] are maybe originally meant for a twin 350.
Honestly i'm not sure what they are, I have at least two I can dig out and take pics of , and if you are patient, might take a week but I will dig and send pic if you PM me. They are here somewhere.
Other than that I might forget I ever posted this.
« Last Edit: November 05, 2011, 02:28:44 AM by fiddy of industry »
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline grcamna2
« Reply #6 on: November 05, 2011, 03:47:21 PM »
The CB350 twins & the CB350/4OOF's all take the same rear sprockets...does any body have a nearly new(very low miles) 35 tooth ?
75' CB400F/'bunch o' parts'
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #7 on: November 07, 2011, 12:53:10 AM »
JT Sprockets makes a 16 tooth front and 39 tooth rear for your bike. Actually, they make the 38 rear too, but no place seems to stock it. Any bike dealer can order these for you through places like Western Powersport, Tucker/Rocky, etc. You need JTF 264.16 and JTR 269.39 (.38 if you can find it). Or just Google those numbers, and see what comes up. The front should cost you around 10 bux, and the rear about 25. Here's a rear on Amazon.com for $19.  http://www.amazon.com/JT-Sprockets-Rear-Sprocket-JTR269-39/dp/B001AVOKAO
Stu
« Last Edit: November 07, 2011, 01:13:12 AM by chickenman_26 »
MCN DTF
Offline 333
  • Time for change
« Reply #8 on: November 07, 2011, 05:59:03 AM »
I like to point out in sprocket threads that unless you have a weird situation and know a single sprocket only has a couple hundred miles on it, that both sprockets and chain need to be changed at the same time.  An old chain with a new sprocket will wear out in less than half the time it should last.  The same with new chain and old sprocket.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline tortelvis
« Reply #9 on: November 07, 2011, 06:28:24 AM »
Check Renthal
Renthal are usually very expensive! JT or Sunstar are great quality and cost much less. If you ever come up with a model with no aftermarket application, try Sprocket Specialists. They will make to order any sprocket you need.
Offline VTCBike750
« Reply #10 on: July 20, 2012, 08:29:35 PM »
So Im in the same boat, but for a 72 750, and trying to find a good alternative to OEM
Been looking around and found some options. I like Z1 enterprises, they seem to be selling EMGO sprockets that are Equivalent to OEM and JT. Anyone had any experience with these?
Not a big fan of EMGO since their ignition switch melted.
-Adam
1972 CB750 (current project)
http://forums.sohc4.net/index.php?topic=87951.0
« Reply #11 on: July 20, 2012, 09:07:52 PM »
I agree with the concept, keep good sprockets on new chains. But i think you can go 2 maybe 3 chains to a set of sprockets.
"Less than half the time" has not been my experience. More like 10-15% faster. Still cost effective.
But i wouldn't tell anyone who wanted to go 1 on 1 not to.
