Author Topic: Cb750 shifter shaft seal  (Read 1303 times)
Offline dhall57
« on: October 14, 2011, 07:20:10 AM »
Im going to replace this seal on my 750 today, is removal of side cover necessary to do it corrrectly or can shaft seal be removed and replaced without taking cover off bike. Just want to be sure to do it right the first time.
thanks
dhall
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Re: Cb750 shifter shaft seal
« Reply #1 on: October 14, 2011, 07:40:47 AM »
thanks
dhall
It can be done w/o removal of cover. Pick the old seal out CAREFULLY, don't scratch the shift shaft. Maybe drill 2 small holes 180deg apart, thread in skinny screws to use to pull the seal out.
Put some lube on the inside edge of the seal where it will pass over the splines on install.
Better if you can remove the cover, have a gasket handy. I'd say most mechanics would not remove the cover, though, for expediency sake.
Offline dhall57
« Reply #2 on: October 14, 2011, 07:48:41 AM »
Thanks Rider!
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
