Author Topic: CB400F Engine paint  (Read 6159 times)
Offline tory b
CB400F Engine paint
« on: October 16, 2011, 05:01:22 PM »
   Does anyone have any suggestions for the correct engine paint for a 1975 400F?
It appears that the engine covers are painted rather than brushed/cleared aluminum like my other Honda's,but it is in need of some detailing to put it lightly.
I was hoping there was an aresol match that I could use to repaint the engine and covers.Maybe dupli-color?
1975 CB400F
1973 CB500
1982 CB900F
1983 GL1100 W/Vetter sidecar
www.vintagericeburners.com
Offline Rigid
  • She likes a
    • KingCustomCycles
Re: CB400F Engine paint
« Reply #1 on: October 16, 2011, 05:07:24 PM »
I like VHT aluminium caliper paint baked at 170 for an hour.  Tough, cheap, and about as Honda silver as it gets.  Got mine at Autozone.
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: October 16, 2011, 06:15:03 PM »
I have used Plasitkote cast aluminum, seems to match well...Larry
Offline fmctm1sw
« Reply #3 on: October 16, 2011, 06:19:38 PM »
I used POR 15 engine enamel on mine.  Photos in my 550 thread....
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline tory b
« Reply #4 on: October 16, 2011, 06:27:08 PM »
Thanks,I will check out all three.
It almost looks like a metalic silver to me.
1975 CB400F
1973 CB500
1982 CB900F
Offline tory b
« Reply #5 on: October 16, 2011, 06:34:26 PM »
I read your 550 thread,but didnt see any photos of the motor?
1975 CB400F
1973 CB500
1982 CB900F
Offline Kwality
« Reply #6 on: October 16, 2011, 10:24:58 PM »
VHT Universal Aluminium.
Previous thread here:
http://forums.sohc4.net/index.php?topic=77515.msg865680#msg865680
Offline Robbnc
« Reply #7 on: October 17, 2011, 04:57:37 PM »
Here's my 400F case I just painted with DupliColor.   I don't know how close to stock this is but I like the color.
Offline fmctm1sw
« Reply #8 on: October 17, 2011, 05:03:41 PM »
Here are some.  Not real good pictures but:  http://forums.sohc4.net/index.php?topic=79666.msg934594#msg934594
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline tlbranth
« Reply #9 on: October 17, 2011, 05:09:28 PM »
I used VHT flat black on my Mac exhaust and am pleased with the result. But the exhaust is steel and aluminum doesn't paint easily. So 'how it looks' is just the first pass. Will it stay stuck to aluminum is the important question.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Robbnc
« Reply #10 on: October 17, 2011, 05:40:24 PM »
another view
Offline rockvegas400
« Reply #11 on: October 17, 2011, 05:42:08 PM »
+ 1 for VHT Universal aluminium.
1975 CB400F
1988 VFR750F-J
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #12 on: October 17, 2011, 05:51:14 PM »
I have about 300 miles on a VHT painted engine and it is holding up well even with gas and oil spills on it.  I did notice one small area that it flaked off and underneath appeared to not have been cleaned well.  A quick wipe with lacquer thinner and a bit of brush touch-up and a short run to warm it up cured that.
Offline jonboycox
« Reply #13 on: October 17, 2011, 06:04:03 PM »
I used Duplicolor Aluminum on my 400F side cases and it matched the original paint flawlessly. The original and the duplicolor sit side by side and aside from 30 some years of age you can't tell the color apart. I also used a clear coat on top. Can't speak to the durability as I haven't got a title or insurance yet and have only been on a few short runs.
Offline tory b
« Reply #14 on: October 17, 2011, 06:13:00 PM »
  I am curios if Honda has actual paint code for the motors?Specifically the 400F.
With the clutch and sprocket covers being painted I want to get it right.
1975 CB400F
1973 CB500
1982 CB900F
