Haha I see your point. Ive done everything else to it besides the clutch too...
To the others, the cam chain is adjusted correctly. Someone also suggested its the regular clutch rattle, its also not that its a different sound and can be felt through the bike when it happens. The drive chain is also correctly tightened, it is a new sprocket and o-ring chain set as well.
I need to change the oil/filter soon anyways so I'll just take the clutch out when I drain the oil and mic. the plates and fibers. Ill also check for bent plates or ridges in the clutch basket fingers.
