Author Topic: starter knowledge anyone?  (Read 1015 times)
Offline 1974blaze
« on: October 19, 2011, 08:07:52 PM »
its a '80 cb400
starter spins freely out of the bike.  sounds like its trying but not succeeding in the bike.  motor not seized.
any thoughts?
also, starter switch is broken.  if i cross the black/white and yellow red in the switch is that the same as pushing the button?  new switch on order.
thanks all.
Offline Danno
Re: starter knowledge anyone?
« Reply #1 on: October 19, 2011, 09:39:47 PM »
sounds like you need a new solonoid or you need to take it out and take it apart and clean it
Offline 1974blaze
« Reply #2 on: October 20, 2011, 06:19:05 AM »
will try that today.  thanks.
« Reply #3 on: October 20, 2011, 10:36:20 AM »
If you take the starter apart, check the brushes for wear. If they are worn out, the starter will crank slow under load, just like with a bad battery.
Offline 1974blaze
« Reply #4 on: October 21, 2011, 10:14:35 AM »
update.
if power is sent straight to starter while installed it just hums.  same if i cross the solenoid poles with a screwdriver.
if power is sent to starter out of the bike it spins freely.
what's the hum? stuck gear in the engine?
trying to fix and sell for a friend.  thoughts appreciated.
thanks.
