Author Topic: Banjo bolt into caliper CB750 F1  (Read 1132 times)
Offline Seeparkfly
« on: October 20, 2011, 04:36:36 PM »
I decided to get SS braided lines straight from my master cylinder to the calipers (dual disc). What size banjo bolt fits into the caliper? Is it a 10 mm x 1.25 or 12 mm x 1.25?
Offline underachiever
  • Squandering my potential since 1989
  • 77 CB550K
Re: Banjo bolt into caliper CB750 F1
« Reply #1 on: October 20, 2011, 04:45:34 PM »
Far as I know all banjo bolts/fittings excluding the bleed screw are 10x1.25. At least mine were.
« Reply #2 on: October 20, 2011, 05:11:08 PM »
There is one also that screws directly in without a banjo. 10x1.25
« Reply #3 on: October 20, 2011, 07:34:32 PM »
Be sure to remove the steel flare seat from the caliper before you try to fit a banjo bolt, and make sure the bolt will thread in deep enough to tighten down on the copper crush-rings before bottoming out. I had to grind a bit off the end of the shortest banjo bolt I had on a K7 caliper.
