Author Topic: Pods and cold starts  (Read 942 times)
« on: October 21, 2011, 07:49:37 AM »
What is the relationship between pods and cold starts?  I would think they make for harder starts, correct?
Offline cameron
Re: Pods and cold starts
« Reply #1 on: October 21, 2011, 07:59:36 AM »
My 550 was always a hard start cold... with PODS.
BUT.. a couple years ago I started riding almost daily, and put in an AGM BATTERY... and I start first try with full choke almost every time.
I might struggle a little if she has sat for more than a couple days..
So.. I could blame it on the pods.. but really I blame it on the Battery.
1976 CB550F
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #2 on: October 21, 2011, 08:02:38 AM »
Popcorn? check. cold weather? check. pod thread? check.  OK, proceed.
« Reply #3 on: October 21, 2011, 08:19:58 AM »
The end of the world is today - we better go down with a fight  ;D
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #4 on: October 21, 2011, 12:27:34 PM »
With podz and popcorn firmly grasped in hand.  :)
Offline crazypj
  • I'm brill, me
« Reply #5 on: October 21, 2011, 12:38:40 PM »
Shouldn't make any difference as Honda use a choke not an enrichener
When you block the intake, it's sucking fuel through the pilot circuit
If  pilot jet is too small, it's too small (but that's a factory/EPA issue)
Cracking the throttle usually makes any Honda (with carbs) hard to start
« Reply #6 on: October 21, 2011, 12:51:33 PM »
Agree completely about the choke plate. Filters upstream from that are irrelevant.  You do have to check the choke plates a closing fully.
However, with the throttle valve held open, fuel is also delivered via the main/ throttle valve orifices as well as the pilot circuit.
Not saying you hold it wide open 'til it starts.  But, a couple of cranking cycles with the throttle held open will suck more fuel into the intake runners (air being blocked by the choke plates).  It's possible to make it way over rich (flooding) the bike this way.  But then, choke off and wide open throttle should clear that up in a couple of revolutions of the crank.
