Author Topic: When did they stop using Bird Bath master cylinder caps ?  (Read 1020 times)
« on: October 21, 2011, 10:15:28 PM »
 I am talking about the concave top models, no writing on them.
I suspect at the end of K1 maybe..
 my partsbook goes to mid 71, and only shows 1 cap. Anyone know when they switched to flat top style? And did they make them in flat, without lettering ?
Hinomaru
Re: When did they stop using Bird Bath master cylinder caps ?
« Reply #1 on: October 22, 2011, 03:00:35 AM »
Are you asking about the CB750 K model?
If so, that master cylinder cap when thru several part number changes:
KO-K1 (concave-unmarked) 45513-300-003
K2 (flat type-marked) 45513-341-671
K3 (flat type-marking change) 45513-341-770
K4-K6 (flat type-marking change) 45513-341-771
I’ve never seen a flat unmarked cap made by Honda for the 69-76 750K.
« Reply #2 on: October 22, 2011, 08:35:35 AM »
 Yes, and I suspected they changed at the K2.
 But, it was also used on the 450, and the 500
« Reply #3 on: October 22, 2011, 09:40:39 AM »
I suspect that the ones without markings are because the label has been peeled off
« Reply #4 on: October 22, 2011, 01:18:05 PM »
 The writing cant peel off. I machine the tops and sides off, on the lathe sometimes..
