Author Topic: The 740 cc"Nazgul "cafe , its awakening  (Read 63908 times)
Offline Emokid
  • Easy you say ? Now where's the fun in that ?
« on: October 22, 2011, 09:26:34 AM »
Well riding season is over up here in the cold north , so its time to start tearing into my 76 550f , been riding it for a few months now , just to get to know it ( and of course enjoy the riding  :) ) .
So whats the plan you might ask ???
In brief my main goal is to get a good looking well performing vintage/racing/cafe style bike .
I will be tearing it to atoms , and start from there  ;D
Engine - keep the 550 bottom , add 650 crank cylinders and head , try to keep the 550 valve cover for the    looks , machine in a cycle x 915 cc overbore piston and sleeve kit , i hope by machining down the outer diameter of the sleeves from 74 to 72 mm i will be able to fit them in the 650 cylinder (fingers xxxxx)
If that is impossible i will go for a 836 kit that will give me a 740 cc (this plan is all thanks to paulages very educational hybrid engine thread , thanks a million for the info )
Body - keep it light , will build my own seat and tank in epoxyresin and fiberglass , leave out all things not essential to performance and looks , so no practical stuff like fenders, chaincover , centerstand ------- ;D
Weight - figure its easier ,and cheaper to loose weight than to add hp , so i have a goal of getting the dryweight below 160 kgs /352 lbs , so i will loose all non essential weight like starter ,fenders,instruments, battery will be a lit/ion 2,4ah
so i hope you all will aid me in my quest to finish this project by mid April , all suggestions and input is highly welcome , and i hope i wont bore you to death  ;)
« Last Edit: June 29, 2012, 09:20:36 AM by Emokid »
-76 550f ,transforming into the 798 "Nazgul" cafe
http://forums.sohc4.net/index.php?topic=97563.0
Offline Emokid
Re: The 550f hopefully to be the 798 "Nazgul "cafe
« Reply #1 on: October 22, 2011, 09:37:28 AM »
strip time  :)
Thats what it looked like a few hours ago , and a little later with a mockup of what i imagine the rear part of the frame should look like , and some brackets removed
« Last Edit: October 22, 2011, 09:53:32 AM by Emokid »
Offline Emokid
« Reply #2 on: October 22, 2011, 10:11:32 AM »
I left the engine in the frame , so i can see what it will look like while i make the plugs for the tank and seat .
Started off with a few pieces of Styrofoam and glued the together with spray on glue .
The seat part dried first so i started with that one  :)
I'm tying to make the lines of the frame tubing flow into the bodyparts , so the back of the seat padding is going to look like an extension of the rear tube in the triangle , the frame tubing will also be visible under the seatpan and cauling( i just have to do something to that ugly upper attachments of the rear shocks to make the frame lines flow more naturally)
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #3 on: October 22, 2011, 10:13:24 AM »
Man, youve got my attention. Looks like the start of a great build.
Offline Emokid
« Reply #4 on: October 22, 2011, 10:18:15 AM »
THIS IS GREAT FUN , I've built cars , and other stuff before , but boy ... I'm creating something from blocks of puffed up plastic !!!!!!!!!!!!
Now for the tank , again i want the lines to flow up from the frame into the body , trying to line up the front tube of the triangle with the back of the tank , and the front of the frame with the front of the tank , and just "bending " those lines together
Offline Emokid
« Reply #5 on: October 22, 2011, 10:19:23 AM »
a little more shape
Offline Emokid
« Reply #6 on: October 22, 2011, 10:20:16 AM »
rounding it of a bit
Offline Emokid
« Reply #7 on: October 22, 2011, 10:24:40 AM »
So some sanding , and then adding some indents for my knees , i will have to wait for my clipons to arrive to see if i have to make some indents for them also , hopefully they will be here in a couple of days now .
And that's how far i got today , i think i will shave some of the top of the tank to make it less square , and look smaller .
please give some feedback to the shape while i can still change it easily ,speak now or forewer hold your peace :D
« Reply #8 on: October 22, 2011, 02:00:35 PM »
I found a great epoxy for lining fiberglass tanks. I dont know the fuel properties in Norway but here it will eat the fiberglass resin and gum up the carbs. Caswell is where I got the epoxy. I heard that POR15 doesnt last too long on the fiberglass.
I like how you cleaned up the floor before taking the pics! no mess, just a magical transformation of foam into parts. Great work so far!
Offline Tews19
  • I am no
« Reply #9 on: October 22, 2011, 02:24:14 PM »
WOW a master with the styrofoam. Seats looks great . is that a mock up? or actual riding seat?
1970 Honda CB750 survivor.
Offline Emokid
« Reply #10 on: October 22, 2011, 03:26:31 PM »
Thanks I knew i had to find a liner for the tank , but i figured that would be no problem since fiberglass tanks are pretty common .
Can you give me a link to the supplier ?
Offline Emokid
« Reply #11 on: October 22, 2011, 03:28:54 PM »
Its a mold for the fiberglass I'm going to use for the seat , just had to squirt some black paint on to see how it would look  ::)
« Last Edit: October 23, 2011, 01:38:27 AM by Emokid »
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #12 on: October 22, 2011, 04:17:11 PM »
You're ambitious with the motor.  I like it ;)
« Reply #13 on: October 22, 2011, 05:33:31 PM »
I thought it would be no problem as well. I got my hands on a vintage tank and was researching around for a liner. All I found were horror stories about the liner peeling off.
http://www.caswellplating.com/aids/epoxygas.htm
Offline Emokid
« Reply #14 on: October 23, 2011, 01:39:43 AM »
Im going to be ambitious with it all , you ll see ;)
here is today's effort in a couple of pics , made the indents deeper to better fit my legs when i tuck in , and rounded of the top a bit .
extended the seat that was a little bit short yesterday .
And sprayed on a little black just for fun (i don't think the pink styro is that pretty  ;D )
Started picking apart the 650 engine I'm going to use as a donor for the crank and cylinders.....
The guy that sold it to me claimed he had turned it just to make shure it wasn't stuck , but that he would not turn it much because the camchain was of........ well he lied , plain and simple , the number three piston was rusted solid to the sleeve , no force could have turned that engine   >:(
I'm using neither the pistons or liners , so it doesn't matter much after all , but still.....
At least the rest looked nice and clean , so i hope the parts will do the job .
Soooo, the original sleeves on the 650 is 65 mm outside diameter , and there is a distance of 11 mm between 1&2 and 3&4 , the 915 sleeves are 74mm OD, witch i plan to turn down to 72 mm OD ( it will keep a 2,5mm wall thickness) but that means there will only be 4mm of aluminium left between the 1&2 and 3&4 , will that be enough , any thoughts on this ??????
« Last Edit: October 23, 2011, 09:22:31 AM by Emokid »
Offline Emokid
« Reply #15 on: October 25, 2011, 12:35:38 PM »
Cylinders and sleeves parted , OMG . i read on the forum that its just to heat up the cylinders a bit , and "tap" the sleeves out ......NOT on this 650 cylinder at least , ended up heating quite a bit , putting the cylinder upside down and knocking the sleeve a bit down , then turning the thing over and using a extractor to pull the sleeves out by the collar one by one , while heating with a propane torch .
It took a while , but i managed to get the 650 sleeves out , and then repeating the whole procedure on the 750 cylinder  :)
so here it is , 650 cylinder and 750 sleeves , ready to go to my machinist , just to get his opinion on how big a bore i can do on the cylinder , he is pretty damn good at high performance tuning so if he says no to the 72mm bore , I'm going to listen and go for a 69mm with 65 mm pistons .
Fingers crossed  :o
Offline SF
  • I burn gas very well
« Reply #16 on: October 25, 2011, 03:57:54 PM »
WHAT DOES "NAZGUL" MEAN? INTERESTING BUILD BTW
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline Emokid
« Reply #17 on: October 26, 2011, 06:06:56 AM »
The Nazgul ,they  are the black riders of Sauron the dark lord , they are the undead that can come back in many shapes , just like this plain old cb  ;D  ( yes I'm a big LOTR fan / nerd )
Offline Emokid
Re: A 550f transforming into the 798 cc"Nazgul "cafe
« Reply #18 on: October 26, 2011, 06:10:09 AM »
OK so i brought the cylinders over to my machine guy , and he says lets go big  ;D ;D
So then i stick to plan A , and one of these has to be ordered:
http://www.ebay.com/itm/Honda-cb750-Cycle-X-915cc-Piston-Kit-big-bore-Cafe-Chopper-Race-/150663092083?pt=LH_DefaultDomain_0&hash=item2314385773
Offline SF
« Reply #19 on: October 26, 2011, 02:57:12 PM »
KOOL THEAM, WOULD MAKE FOR KILLER PAINT JOB.
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
Offline Tews19
  • I am no
« Reply #20 on: October 26, 2011, 05:01:24 PM »
OHH MAN, thats going in the 550!!!!! I can't wait. What kind of time period are you looking at to get the engine running again?
Offline articblue
« Reply #21 on: October 27, 2011, 05:03:52 AM »
watching interested in the theme / name
Eventually I'll get something that runs, but until then I'll wrench until I make it run.
Project 750
Also, another 'new' project 1975 Honda CB400F.
Offline MoMo
  • Ride like you're invisible
« Reply #22 on: October 27, 2011, 06:20:45 AM »
I agree with the tank shape, aesthetically the top does look too heavy and square-at least in the photo.  Ambitious plan, I will be following.  I would have thought the block space between the liner walls insufficient...Larry
Offline henrikm
« Reply #23 on: October 27, 2011, 07:52:25 AM »
[norwegian] Veldig interessant, følger med! :) [/norwegian]
Very interesting start. Just about to start my 750 cafe build and am also planning to do my tank and seat in fibreglass. Will follow your build closely.
Offline Emokid
« Reply #24 on: October 27, 2011, 09:38:32 AM »
Yep , will take a bit if the top to make the tank more slim, and look smaller .
About the liners -they may actually show between the cooling ribs of the 1-2 and 3-4 cylinders , im not quite shure , but we will machine a smaller collar , and see how we best can adjust the outer dim of the liners , with 72mm OD there should be aprox 5 mm left between the liners .
