Author Topic: The 550f weightwatcher tread  (Read 1332 times)
Offline Emokid
  • Easy you say ? Now where's the fun in that ?
« on: October 23, 2011, 10:23:20 AM »
I'm not shure if this tread is in the right place , if its not please let me know .
In my head weight is very important to performance , and in my build i aim to loose as much luggage as possible , so i started picking it all  apart , and while doing so i figured i would weigh all the stuff i took off , so here is the guide to what the individual parts of the 550 weigh , if you plan on loosing some weight of yours or replace some items with lighter stuff ,you can sort of figure out the total before turning a screw :D
All stock items, rounded of to nearest 50g ( 1000g=2.205 lbs)
gastank                                     4300g
seat                                           2150g
battery                                      4250g
battery tray                                 850g
rele board with all comp            1100g
air filterbox complete                  1500g
bar behind seat                         1050g
rear fender with taillight            2500g
front fender                               1700g
headlight                                   1450g
clutchhandle /switch                    500g
throttle with wire                         600g
handlebar with clamp                1700g
instruments                               1900g
mastercyl w. brakelight switch    900g
brake caliper                             1300g
exhaust 4-1                              7400g
chainguard                                  900g
footpegs pair                             1250g
brake pedal                                 650g
wiring loom                                  700g
startermotor                              2250g
horn/ignswitch/blinkers               750g
brackets cut of for cafe style     1100g
I will extend the list as i pick stuff of , hope it will be useful to someone  :)
-76 550f ,transforming into the 798 "Nazgul" cafe
http://forums.sohc4.net/index.php?topic=97563.0
