Author Topic: spark arcing from plug booty to head.......  (Read 2116 times)
Offline stinkfinger
  • Dirtbiker at heart
« on: October 25, 2011, 11:52:46 AM »
77 CB750A.  #2 cylinder firing intermittently so I changed plug and low an behold.....
Its arcing across to the engine head from the rubber spark plug booty! (not touching)
Never seen that one before, anybody ever seen something like this?
Spark jumping from rubber/plastic to metal, whoda thunk it?!
I guess the coils are putting out enuff juice ;D
Thanx
Tony
Dualsports are an all access
back-stage pass to nature.
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: spark arcing from plug booty to head.......
« Reply #1 on: October 25, 2011, 11:59:03 AM »
Happens all the time when boots are worn and don't insulate properly.
« Reply #2 on: October 25, 2011, 12:43:09 PM »
replace all the plug caps,the 2 plug fouled from weak spark from that cap,it cant get through so it sort of bursts out the side.
Offline stinkfinger
« Reply #3 on: October 25, 2011, 01:22:29 PM »
Fixed, for now.... :) black electrical tape to the rescue!
She's purrin like a kitten again.
Will replace the caps..........thanx guys
Tony
Offline Deltarider
« Reply #4 on: October 25, 2011, 01:57:56 PM »
Every SOHC four rider should make it a habit to check for sparks in the dark, every 3000 km or 6 months whatever comes first. It's often overlooked and people start taking their carbs apart and what not.
CB500K2-ED Excel black
Offline fmctm1sw
« Reply #5 on: October 25, 2011, 02:20:21 PM »
+1.  I had THREE of the four arcing on one of my bikes...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #6 on: October 25, 2011, 03:48:38 PM »
carbs come apart more times than they need to,often over and again when the trouble is an easy fix elsewhere.
Offline tlbranth
« Reply #7 on: October 25, 2011, 05:13:05 PM »
I noticed this phenomenon on my bike in the early 70's. A friend who was an electonic whiz told me that washing the bike and letting the water evaporate from the caps and wires leaves minerals on them which can conduct electricity. I believed him.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Raul CB750K1
« Reply #8 on: October 26, 2011, 02:15:27 AM »
Just the other day I saw arcing on boot #4 of my CB750. Never seen that before.
Coincidentially, I had pressure washed the bike the day before. Removed the boot and everything seemed fine -if only for a dull copper colour-, but then I took a day-long ride with no rough running whatsoever...
« Reply #9 on: October 26, 2011, 02:27:31 AM »
i blow mine dry around the carbs/fins and plugs with compressed air after a wash.
Offline Deltarider
« Reply #10 on: October 26, 2011, 03:58:00 AM »
True.
I agree with Dave. Check your ignition electrics and check it again before you even think of suspecting the carbs.
