Author Topic: Engine paint  (Read 1482 times)
Offline stevenwr
Engine paint
« on: October 25, 2011, 03:52:32 PM »
Hello, I've just purchased a 1974 CB550 and want to paint the engine as close to the original silver as I can. What paint are people using? I'm assuming you primer first then paint.
Offline phil71
Re: Engine paint
« Reply #1 on: October 25, 2011, 03:59:58 PM »
marbles motors has the cloud silver paint you need.
Offline stevenwr
Re: Engine paint
« Reply #2 on: October 25, 2011, 04:36:42 PM »
Thanks.
Offline Teknojeffo
Re: Engine paint
« Reply #3 on: October 25, 2011, 07:48:24 PM »
Is that the same paint color as the 750k's ('74 and '76 in my case). I want to do some touch-up this winter too.
Any special kind of primer?
'74 CB750
'76 CB750
GL1000 (Pete Boody restoration)
Offline CycleRanger
  • No comment about being an
Re: Engine paint
« Reply #4 on: October 25, 2011, 08:23:40 PM »
Duplicolor silver engine paint is pretty much an exact match.
Offline phil71
Re: Engine paint
« Reply #5 on: October 26, 2011, 01:55:30 AM »
i don't believe that engine parts had primer, but the sides had a clear coat.
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
Re: Engine paint
« Reply #6 on: October 26, 2011, 05:15:48 PM »
I tried some cloud silver on my oil filter cover the first time I changed my oil this summer. It wasn't close enough for my taste. 2nd oil change I used the Duplicolor on the cover and it is spot on.
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline racemx51
Re: Engine paint
« Reply #7 on: October 26, 2011, 05:30:49 PM »
No primer on engines. And automotive paint is fine.. A car hood in AZ gets to 220 to 250 degrees, which is the highest these motors would get..
