Author Topic: CB750 Engine Howl  (Read 947 times)
Offline turkey4me
  • The closer you are the less you can see!
CB750 Engine Howl
« on: October 25, 2011, 08:27:18 PM »
Please take a listen to this you tube video clip.  After about 20 seconds I pull the clutch and you can hear a fairly loud howl that I think is coming from the primary gear drive.  Is this normal for a 76 CB 750F?  Has me somewhat concerned.
CB Engine
<iframe width="425" height="349" src=" frameborder="0" allowfullscreen></iframe>
Offline CycleRanger
  • No comment about being an
Re: CB750 Engine Howl
« Reply #1 on: October 25, 2011, 08:30:30 PM »
egads! :o
Have you found anything unusual in the oil pan yet?
Offline wrenchmuch
« Reply #2 on: October 25, 2011, 08:41:28 PM »
Does it make the sound if you get it into neutral after pulling the clutch in? Can't tell direction of sound from a video clip . Do you think its coming from inside the engine ? If its internal I bet its coming from the transmission . Check the sump like CR suggested .
CB750K1
CB750K4
Offline turkey4me
« Reply #3 on: October 25, 2011, 08:51:05 PM »
I'll check the sump and noise with gear in neutral.  I don't hear much below 30 mph.  In the video I am doing about 50 when I pull the clutch.  Noise is definitely coming from the left side of motor
« Last Edit: October 25, 2011, 08:55:57 PM by turkey4me »
Offline cben750f0
« Reply #4 on: October 25, 2011, 09:13:52 PM »
whats your chain and sprockets like, and badly worn chain will howl when it runs dry of lube... just a thought.
peace
Offline ofreen
« Reply #5 on: October 25, 2011, 10:05:00 PM »
peace
Yes, especially at the countersprocket.
Greg
'75 CB750F
Offline cben750f0
« Reply #6 on: October 25, 2011, 10:11:31 PM »
exactly, when he said from the LH side, that got me thinking...thanx for the back up=)
peace
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #7 on: October 26, 2011, 07:21:01 AM »
wierd.  almost sounds like when you try to stop a bicycle tire from spinning with your shoe when it first starts.  tire rub?  chain and sprockets?  on mine there is a piece of rubber  like material on the lug inside the front sprocket cover.  could yours be loose?
MATT
