Author Topic: 21' front an rear or 16' front an rear  (Read 3266 times)
Offline luap
  • LAWL
« on: October 26, 2011, 11:07:51 PM »
Im starting an 550 hartail build, the wheel have me at a stand still right now my first plan was to run a narrow glide 19 with a 3/4 axle up front under a dna springer front end 4 under 20' length, would be the easiest i wouldnt need to do any machine work for the axle, an then just run a 16x3 harley wheel laced to the honda hub, cool but done over an over, then im thinking same rear set up but front 16x3 laced to a cb400 front drum hub, need to get wheel spacer machined all balls has bearing that can get it close but not 100% if I go with that set up im going to run these tires https://www.universaltire.com/motorcycle-tires/500-16-indian-script-m-c-tire-blackwall.html ,but then I was thinking ordering 2 21' by 1.85 an lacing the cb400 hub up front an the 550 hub in the rear  the excel wheel from buchanas ,http://www.amazon.com/Avon-Speedmaster-Front-Tire-3-00-21/dp/B000GRSJAK tire something like that If I go with the 21
 special order spokes on most all the set ups i mentioned,
So any suggestions might help speed me up a bit thanks
how do you think the ride would be with a 21 up front an rear compared to 16/16
paul
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline luap
  • LAWL
Re: 21' front an rear or 16' front an rear
« Reply #1 on: October 26, 2011, 11:36:12 PM »
heres ones of the only pictures I can find with a 21' rear
http://www.dirtysouthchoppers.com/files/sporty23.jpg
www.cb-town.com
Offline singedebile
« Reply #2 on: October 27, 2011, 05:40:08 PM »
I like it!
kinda gives the bike an overgrown board track racer look, expecially with that harley motor... not sure what it would look like with our straight four, but my interest is peaked.
1975 cb550f super sport, 1976 Yamaha IT400, 1974 Suzuki T500
« Reply #3 on: October 27, 2011, 06:11:25 PM »
CycleX does a 21 inch front conversion. If you are going Hardtail why not 16 rear and 21 front..... Actually i like the chunky look of the 16 front and rear..  ;)
http://www.cyclexchange.net/Wheel%20Page.htm
Check the link, every combination of wheels and stuff......
Offline luap
  • LAWL
« Reply #4 on: October 27, 2011, 08:51:28 PM »
I dont want to do 16 rear an 21 front, I know its not the end of the world but I like the tires to match, I like the 16x16 also but wanting to do something different I was on ebay the other say an saw a 400 with 16/16,  It looked great more of a old school look, but after seeing it I want to do somthing I havnt seen 21/21. thanks for the reply was thinking maybe I should have posted in project section
www.cb-town.com
« Reply #5 on: October 27, 2011, 08:57:16 PM »
I have a pic of a bike with 21 front and rear, i'll see if i can find it for you....
« Reply #6 on: October 27, 2011, 09:12:05 PM »
Here you go....
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #7 on: October 28, 2011, 07:44:33 AM »
Or this, I remember reading those are 23's!
« Reply #8 on: October 28, 2011, 08:14:48 PM »
 I have a Honda belt drive rear wheel that uses about a 2.25or 2.5 rim in 16 inch, that looks like a 77/78 17" rim.
 I think its 36 hole..
 Does that help any ?
Offline luap
  • LAWL
« Reply #9 on: October 28, 2011, 10:24:56 PM »
rocket thanks man, that thing to me is awsome an its on a "street" bike I think it might even look a little better on a bobber, the other night I was thinking doing the 21/21 would end up being way out of budget, today I called buchanas an they can make the rear laces for 21' to stock honda hub for 88.00 an the front 21' to cb450 hub for 68 bucks, they are only steel but I dont mind since I am planning on powdercoating them anyways, but now after seeing that bike Im thinking maybe Ill stick with the stock front end instead of the dna springer I have,
thanks 754 but im going with the 21/21
www.cb-town.com
Offline luap
  • LAWL
« Reply #10 on: October 29, 2011, 12:55:52 PM »
TSA carrys the entire set up, have to see if they can do the front set up with the 450 hub
http://home.comcast.net/~tas-motorsports/777F.jpg
www.cb-town.com
