SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Float Needle Question...K3
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Float Needle Question...K3 (Read 909 times)
Johnie
Really Old Timer ...
on:
October 27, 2011, 06:04:48 PM »
Regarding the CB750K3...just how important is it that the spring loaded nipple on the float needle be working vs stuck? The spring nipple on the other 3 is fine, but this one does not move. It is stuck all the way out.
Logged
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI USA
CycleRanger
No comment about being an
Central Texas Shop Manual Advocate
Re: Float Needle Question...K3
Reply #1 on:
October 27, 2011, 06:31:46 PM »
You might try soaking it in something slick. If it won't come unstuck I'd replace it.
Logged
CB750K5 '79 XL250s CL350K3
CB750K3 '76 XS650 '76 CJ360T
Johnie
Reply #2 on:
October 27, 2011, 06:34:34 PM »
Had it soaking in Gunk carb cleaner for 3 hours. No change probably because the cleaner could not get into the spring area. Just forced some spray carb cleaner in there hoping it works.
Logged
Oshkosh, WI USA
MoMo
Ride like you're invisible
Reply #3 on:
October 27, 2011, 06:36:30 PM »
I was able to free up a stuck pin with a heat gun. It needs to be free in order to maintain proper float height...Larry
Logged
Johnie
Reply #4 on:
October 27, 2011, 06:38:25 PM »
Heat gun...will give it a try. I want to save it since there is only 5,310 miles on this bike. The seat and needle are very good on contact areas. Thanks for the tip.
Last Edit: October 27, 2011, 06:40:02 PM by Johnie
Logged
Oshkosh, WI USA
Johnie
Reply #5 on:
October 27, 2011, 07:01:43 PM »
Got it...the heat gun worked. Thanks...
Logged
Oshkosh, WI USA
MoMo
Reply #6 on:
October 27, 2011, 07:03:41 PM »
You're welcome. It seems that I use a heat gun most every day in my shop...Larry
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
