Author Topic: CB750K2: Length of Tach Cable  (Read 662 times)
« on: October 28, 2011, 10:09:15 AM »
Hi guys: CB750K2: So I bought these cables from Motion Pro. The Speedo Cable is right on. The MP tach cable is 3 inches longer than what I was running. Thing is, what i was running has a gray cover, so it can't be stock. It did fit nicely.  But the MP cable is obviously incorrect, it loops out in front of the triple tree.
MotionPro said they would cut down the cable to my specs no charge,  provided I gave them my original cable to look at. That's only fair. Problem is my cable is not an original. So if one or two of you could measure yours and report back, i could use that as my backup.
To match their cable to a non-original would be a custom charge. They acknowledged that it is very difficult to maintain a database of cable lengths. I would expect especially so on a tach cable which isn't a high demand item. But i can't imagine what that 27" tach cable would fit. Maybe a DOHC?
My cable is 24" and the MP is 27". Just measure the sheath, with the drive end, but not the nut on the other end, and let me know. Thanks.
« Last Edit: October 29, 2011, 07:23:49 AM by MCRider »
Re: CB750K2: Length of Tach Cable
« Reply #1 on: October 29, 2011, 07:22:16 AM »
bump
Offline Johnie
« Reply #2 on: October 29, 2011, 07:27:50 AM »
MC...OEM tack cable is 24 1/4th inches.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #3 on: October 30, 2011, 05:24:23 AM »
Thanks for that. I'd like to get one more confirm of this before submitting to Motion Pro. Anyone?
Offline Johnie
« Reply #4 on: October 30, 2011, 07:30:00 AM »
My measurement was off a CB750K4. That measurement was from the lower cable housing end to the top housing end. I did not include the top fastener in that size.
« Last Edit: October 30, 2011, 07:31:43 AM by Johnie »
Oshkosh, WI  USA
« Reply #5 on: October 30, 2011, 09:19:18 AM »
Thanks, that's the consistent way to measure. The housing with its permanent endings, but not the spin nuts etc.
I checked the parts fishy and we have the same cable, though its been upgraded from "300" center digits to "449" center digits.
