Author Topic: Mystery (To Me) Hose - CB500 - Help  (Read 659 times)
Offline Chachi
« on: October 29, 2011, 02:27:40 PM »
Can someone please tell me what this is and what it connects to (and that it's easy and no big deal).
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline Chachi
Re: Mystery (To Me) Hose - CB500 - Help
« Reply #1 on: October 29, 2011, 02:29:28 PM »
If it helps... all I know is that the other end of it is grouped in with my overflow tubes.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline haill
« Reply #2 on: October 29, 2011, 02:53:12 PM »
it might be the  breather tube but you need to pull back some to get a better view of the carb rack, remove the tank and take a shot down through from the top of the bike. they are located between the 2nd & 3rd carb there are two of them for each side. looks like it has pulled out. should slide back in...
Offline Chachi
« Reply #3 on: October 29, 2011, 03:52:01 PM »
Thanks. I think that is it. I see the other one. The one still connected seems to drain in front of rear wheel whereas this one is tied in with my 4 carb overflow tubes. I don't have good light to see right now, but it doesn't exactly look like an easy place to get to secure back on. Any tips?
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline d9canada
« Reply #4 on: October 29, 2011, 05:02:40 PM »
I have a variety of straight and curved nosed locking forceps.  They are stainless steel so they last forever and they are really cool for delicate or hard to get-at things.  You can use them not only to slip the hose into place but also to get the stupid ring clamp weasled into position too.  You can often buy sets at tool discounters or look around tool sections in thrift stores.  If you know someone in the medical business, they often have access to stuff that is being obsoleted.  Don't leave home without it!
Brian
CB350F to CB900C
GL500
GL1000
CBX
02 Sportster 883
64 Suzuki M15D Sovereign 50cc
Offline fastbroshi
  • Puppet
« Reply #5 on: October 29, 2011, 10:50:41 PM »
Those little barbed ends seemed to be cast into the bodies on my carbs.  Hope it didn't snap off.
Just call me Timmaaaaay!!!
Offline Chachi
« Reply #6 on: October 30, 2011, 08:30:35 AM »
It seems I was able to push it back in its proper place. As seen in the pic, my hose was connected to that metal end. I kept that intact and pushed the metal end in. Going to ride now, hopefully it's in secure and stays put.
Does anyone know if that metal end should be able to come in/out like that or if in fact it is supposed to be cast in and only the hose should come on/off?
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
« Reply #7 on: October 30, 2011, 09:20:50 AM »
not sure if it's really cast in...I think it is more of a press in deal...as long as it stays put and doesn't leak gas out or vacuum it'll be fine...if it keeps coming out, maybe put a little threadlock on there or something...
Offline Chachi
« Reply #8 on: October 30, 2011, 10:14:40 AM »
It seems to be staying put and not leaking, etc. I will watch it. Looks like parts diagram (Carb) refers to the two as Bulk Hose.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
