Author Topic: help with my 72 honda cl350 tail lights and blinkers  (Read 886 times)
Amos90
« on: November 01, 2011, 11:23:55 AM »
Hey guys for some reason my tail lights and blinkers dont work and its not the bulb all the wires look fine also. And my green and yellow light for neutral and kick stand dont work either wondering if there is a fuse and if so where at? Preciate any help!!!
Offline grcamna2
Re: help with my 72 honda cl350 tail lights and blinkers
« Reply #1 on: November 01, 2011, 01:03:13 PM »
I recommend going into your "mass" of wires in the headlight;carefully check all those wires & make sure you have good,clean & tight color to color connections;remove the tank & check the wires near the coils also...you may have some broken double-female connectors or possibly corroded frame to harness ground strap connections.
75' CB400F/'bunch o' parts'
