Author Topic: Are valves matched to their seat?  (Read 2099 times)
Offline Scott S
« on: November 01, 2011, 02:35:32 PM »
 What I mean is, if I disassemble a head for cleaning and porting/polishing, do I need to keep the valves with the cylinder/seat they came out of?
 They will be, at the least, lapped before being reinstalled.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Re: Are valves matched to their seat?
« Reply #1 on: November 01, 2011, 02:44:31 PM »
yes you MUST keep each valve in its original seat.
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #2 on: November 01, 2011, 02:54:49 PM »
If you are renewing the guides and cutting the seats, No.  If you are only lapping the valves, yes.
Offline trueblue
« Reply #3 on: November 02, 2011, 05:17:35 AM »
+1
1979 CB650Z
Offline Scott S
« Reply #4 on: November 02, 2011, 05:30:12 AM »
 What about springs and keepers? I'll probably get individual baggies and keep everything together the way it came out, but just curious about the springs.
'71 CB500 K0
'81 Yamaha XS650
Offline tango911
« Reply #5 on: November 02, 2011, 06:04:53 AM »
I did just that.  I kept the valves and springs etc... in separate baggies and labeled them 1-4.
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
Offline MoMo
  • Ride like you're invisible
« Reply #6 on: November 02, 2011, 06:40:01 AM »
Not necessary with the springs but I always use the baggie method to keep everything ordered-same with carb rebuilds...Larry
« Reply #7 on: November 02, 2011, 06:56:09 AM »
But...if you're really anal... get a spring gauge and check that they are all of similar strength.
Naw... don't worry about it.   :)
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #8 on: November 02, 2011, 07:56:53 AM »
Valves stretch in length, springs lose their strength, where does it end?
« Reply #9 on: November 02, 2011, 08:06:53 AM »
Can a valve actually stretch?  I can see where the notch holding the keepers could wear, causing the appearance of stretch by looking at the spring. I can see the seat settling causing the valve to rise closing the lash.
Anyway, live and learn.  :)
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #10 on: November 02, 2011, 08:27:12 AM »
Yeah, Lycoming actually sells a contour guage to check their valves for stretch.  It fits between the stem and the top of the valve head.  I have not seen one for any other valves but it makes sense with the recurring tension and temperature variations that the valve would eventually get longer.
Offline the technological J
  • deliciouso!
« Reply #11 on: November 02, 2011, 08:52:40 AM »
i had a peice of cardboard with 8 holes(two rows of 4) labeled 1-4 and in and ex and then it was easy to lap them and put them back as well as clean the carbon off em or polish them
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline Scott S
« Reply #12 on: November 17, 2011, 07:40:03 AM »
 Is there a trick or an easy way to disassemble the head at home if I don't have a valve spring compressor tool?
'71 CB500 K0
'81 Yamaha XS650
« Reply #13 on: November 17, 2011, 08:24:29 AM »
You can get (borrow) a spring compressor from the local auto parts store, usually for free. The smallest autoi size may still be a bit large for you, but it can done.
Good VSC kits are $40-$60.
http://www.amazon.com/MOTORCYCLE-DIRTBIKE-VALVE-SPRING-COMPRESSOR/dp/B004NV21YA
I'd spend a little more than this myself. But if its a one timer... resell on ebay.
  • deliciouso!
« Reply #14 on: November 17, 2011, 08:56:02 PM »
if you know a welder you could have him make you something out of a c clamp.... but for dissasembly i have put a large socket on them and smacked the with a hammer... it works but you def need a valve spring compressor for reassembly
94 ST1100..Gone
« Reply #15 on: November 17, 2011, 10:04:45 PM »
with the socket whack method,stuff the combustion camber full of rag on the pair of valves you are removing,itll stop them from compressing down,watch those collets(keepers).
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #16 on: November 18, 2011, 02:44:20 AM »
That explains the bent valves I removed ............ ::)  ................. buy the proper tool.
« Reply #17 on: November 18, 2011, 02:49:49 AM »
i dig that k,i mean rigid,,it takes a certain finesse,for one the socket has to clear the stem and seat on the retainer cleanly,and the blows have to have some knowledge behind them,blindly belting #$%* only results in tears,,lays waste to my favourite saying of "WHEN IN TROUBLE OR IN DOUBT,GET A BIGGER HAMMER OUT!"
