Author Topic: CB750 gearing  (Read 3526 times)
1198bmw
CB750 gearing
« on: November 02, 2011, 09:17:51 AM »
Hi all,
I have a 1978 CB750 K8.
At 60mph its reving at 6500rpm- surely thats to much.
Its got 15t front sprocket and 41 rear and a 17 in rear wheel which i'm told is correct for this model. Was there a gearing problem with these models and what is the solution.
1198bmw
Re: CB750 gearing
« Reply #1 on: November 02, 2011, 09:20:13 AM »
Hi all,
1198bmw
Either the clutch is slipping or the tach is wrong.
Could be something else, but that's my vote.
Offline I Zombie
Re: CB750 gearing
« Reply #2 on: November 02, 2011, 01:43:45 PM »
I've kinda got the same issue, but after new clutch & springs & countless adjustments, i'm guessing my tach is off. My tach say's I'm idling @ 2000rpm, but many a buddy say's "it sure don't sound like 2000 to me"
« Last Edit: November 02, 2011, 02:22:50 PM by I Zombie »
78 CB750K
Offline TommyT
Re: CB750 gearing
« Reply #3 on: November 02, 2011, 01:46:16 PM »
my 1978 cb750K tach reads 2100 rpm at idle, but my dwell/tach tells me it's at 950-1000.
Re: CB750 gearing
« Reply #4 on: November 02, 2011, 01:47:32 PM »
Hmmm...all 78Ks. Coincidence?
Offline zzpete
  • You better get an
  • 1969 CB750, 1971 CB750
Re: CB750 gearing
« Reply #5 on: November 02, 2011, 02:08:37 PM »
I read in the FAQ: http://forums.sohc4.net/index.php?topic=372.0
With the 15/41/630 setup, the bike spun in 5th at 70MPH, 5300RPM.
If memory serves correct my 1977 CB750 K was about 5100 RPM at that speed. Tire size, clutch slippage, etc. could also be factors.
"One of the things that make motorcycling so great because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: CB750 gearing
« Reply #6 on: November 02, 2011, 02:11:22 PM »
I haven't seen a tach on these bikes yet that were accurate.
Offline zzpete
  • You better get an
Re: CB750 gearing
« Reply #7 on: November 02, 2011, 02:12:13 PM »
Me neither!!!!
Offline coma13
  • Lex Talionis
Re: CB750 gearing
« Reply #8 on: November 02, 2011, 02:24:10 PM »
are aftermarket tachometers any more accurate? or is it something in the tach drive that causes inaccuracy?
They wail and weep,
The march of the sheep,
As they go to that cross on the wall.
Offline I Zombie
Re: CB750 gearing
« Reply #9 on: November 02, 2011, 02:28:32 PM »
I haven't found a spare 1 to try yet, I've just been runnin it as is for the last few years.
78 CB750K
Re: CB750 gearing
« Reply #10 on: November 02, 2011, 02:33:05 PM »
Tach drive not an issue. Its mechanical and foolproof.
An aftermarket tach would be more accurate, mostly because its new. Or electronic. If its a custom bike, I'd go that way.
Earlier K series tachs are pretty good. Being that we're talking about 4 78Ks here sounds like that year tach had some issues. But I think a refurbish would fix it. If you want to stay stock looking.
A shop I talked to would do it for $85. open it up, clean and lube it.
Buying a new one would be pricey, and you still don't know how old it is. Could have set on the shelf for a while. The lube goes bad from gravity and condensation.
Offline I Zombie
Re: CB750 gearing
« Reply #11 on: November 02, 2011, 02:36:53 PM »
I was thinkin of the mini speedo & tach combo from Cycle X, $70. Lose the bulk & clean up my tree's a bit & hopefully get a better reading too.
78 CB750K
Offline coma13
  • Lex Talionis
Re: CB750 gearing
« Reply #12 on: November 02, 2011, 04:44:14 PM »
I've got a 77K and I already replaced the stock tach with a little aftermarket mechanical one but I haven't started the bike up yet. Hopefully I don't run into any issues with that guy!
They wail and weep,
Offline I Zombie
Re: CB750 gearing
« Reply #13 on: November 03, 2011, 06:20:02 AM »
[/quote]
I'd love to know if it fixed the issue or is more accurate
78 CB750K
bollingball
Re: CB750 gearing
« Reply #14 on: November 03, 2011, 06:57:46 AM »
I just listen to the motor. ;)
