Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
This is not a pod threadThis is not a #$%* on my vacuum gauges threadThis is a help or GTFO thread.
If I remember correctly, Keyster had a fitment problem with some components. Like the angle of the tip of the float valve was not right and the taper of the needles was off. Things like that.
