Author Topic: Exhaust Popping  (Read 1723 times)
kaysystems
Exhaust Popping
« on: May 06, 2005, 10:07:28 AM »
CB750 K0
What causes the exhasut to 'pop' while at idle? Running slightly rich. Timing is spot on. No air leaks in the intake.
thanks
David
Offline Bob Wessner
  • "Carbs Suck!"
Re: Exhaust Popping
« Reply #1 on: May 06, 2005, 10:49:29 AM »
Did you check/adjust the valves?
kaysystems
Re: Exhaust Popping
« Reply #2 on: May 06, 2005, 10:56:21 AM »
Yes, but I'm wondering if I have a stuck or damaged one. I'm going to check them hot.
David
Online bryanj
Re: Exhaust Popping
« Reply #3 on: May 07, 2005, 04:08:09 AM »
Popping is usualy air leaks on the exhaust.
Offline Gordon
  • 750K1, 550K2
Re: Exhaust Popping
« Reply #4 on: May 07, 2005, 05:37:36 AM »
I'm with Bryan on this one.  Had the same problem on my 750 when I first rebuilt it.  Turns out I didn't have the headers seated all the way in and clamped down tight enough.
