Author Topic: fireing cable order from coils  (Read 3323 times)
Offline xsmooth69x
« on: November 11, 2011, 04:33:23 PM »
so just to make sure im not retarded how do you wire the cables to the cylinders from the coils.......
the gray thing at the bottom of the pics are the seat like your sitting on the bike ready to ride. the blue things are handle bars
picture #1 with the crossed wires
or pic #2 just straight
1975 CB550 (FINISHED?!?!?)
Offline onepieceatatime
Re: fireing cable order from coils
« Reply #1 on: November 11, 2011, 04:44:39 PM »
I think it is picture 3...
I am pretty sure 1 and 4 are off one coil, 2 and 3 off the other.
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #2 on: November 11, 2011, 04:56:42 PM »
yep. pic #3.  1.4 fire off the blue points wire while 2.3 fire off the yellow.  Assuming stock equipment, of course.
And to answer your next question, yes, each cylinder has not only a "good spark" at the end of it's compression stroke, it also has a "wasted spark" at the end of it's exhaust stroke.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline xsmooth69x
« Reply #3 on: November 11, 2011, 05:07:45 PM »
picture #3 sounds good
thanks guys  8)
« Last Edit: November 11, 2011, 05:10:40 PM by xsmooth69x »
Online dave500
« Reply #4 on: November 11, 2011, 06:27:47 PM »
from the points,use blue wire for 1/4 and yellow for 2/3
Offline xsmooth69x
« Reply #5 on: November 12, 2011, 01:42:35 AM »
gottcha ill make sure that is hooked up right too   :)
Online dave500
« Reply #6 on: November 12, 2011, 01:47:33 AM »
cool,,so with coil that has the blue wire,,make sure the leads go to #1 and #4,,and the coil with the yellow wire the leads go to #2 and #3,,it dosent matter which lead of the pair go to which plug,,as in 1 and 4 can be swapped and its ok,,and 2 and 3 can be swapped and its ok,,ok?
Offline xsmooth69x
« Reply #7 on: November 12, 2011, 02:57:01 AM »
lol got it  ;D
Online dave500
« Reply #8 on: November 12, 2011, 03:13:25 AM »
dont lol just do it.
Offline xsmooth69x
« Reply #9 on: November 12, 2011, 03:28:24 AM »
yup they are correct my coils and wires are good  8)
Online dave500
« Reply #10 on: November 12, 2011, 04:26:13 AM »
how come i can see a mushroom cloud coming from your place then?
« Reply #11 on: November 12, 2011, 06:11:12 AM »
Maybe he's using Plutonium Plugs?
Sure.
Is it hard?
Offline xsmooth69x
« Reply #12 on: November 12, 2011, 11:52:07 AM »
im half japanese mushroom clouds are a common occurrence around here  :P
Online dave500
« Reply #13 on: November 12, 2011, 03:59:55 PM »
no offence.
Offline xsmooth69x
« Reply #14 on: November 13, 2011, 05:46:19 AM »
