Author Topic: 2013 honda concept. 76 550 with cbr600 f4  (Read 29053 times)
Offline Mercuno
Re: 2013 honda concept. 76 550 with cbr600 f4
« Reply #100 on: December 21, 2011, 05:41:32 pm »
as for the frame--Absolutely-- I dunno about the swingarm ? I havent really seen the need for any more than what it has. It wont have any real torsion applied to it transversely and I have not extended it.
I am more than doubling the power to this bike and for anyone who wants to try this you do so at your own risk. You absolutely must reinforce the frame even though you will be using the engine as a stressed member the rear portion of the bike has a visible flex to it.
« Reply #101 on: December 21, 2011, 08:38:41 pm »
I dunno about the swingarm ? I haven't really seen the need for any more than what it has
If you don't do something with that swing arm it will be the weak link in this project. The forces transfered to it by the 100HP+ that engine will produce, will be trying to turn that arm inside out.... Even Racers with 25% less HP on 500-550?4's brace their arms {or use better ones} , I would definitely be bracing it if it were mine or use a different arm.....
Offline Syscrush
  • Sold. :(
« Reply #102 on: December 21, 2011, 08:50:31 pm »
Probably more like tripling.
When you say that the rear portion has a visible flex, what do you mean?  What's making it flex?
Offline Mercuno
« Reply #103 on: December 22, 2011, 12:59:27 am »
well I wasnt really too familiar with the 550 by far. My first motorcycle ever on a whim.
The rails where the seat is were able to have some up down relative to each other. I am just guessing here but seems to me that one of the P.O.'s cut off a bar that bridges/braces the two rails. I plan on cross bracing as well.
Its hard for me to envision until I can get it where it will (in theory) be a runner and then reverse the process all the while buffering the entire system.
I also have ears to hear so I will surely be bracing the swingarm.
« Last Edit: December 22, 2011, 01:01:34 am by Mercuno »
Offline y2kc0wb0y
  • B00msh0cka
  • Shoot the pickle....
« Reply #104 on: December 22, 2011, 05:23:35 am »
Subscribed....
CB750K3 890cc| 2004 VFR800A| 76 CB550F| 77 CB750F| 73 CB350G| 79 XLH| 2007 BMW R1200GS| CB750K2
Offline Syscrush
  • Sold. :(
« Reply #105 on: December 23, 2011, 07:07:52 am »
If you are keeping the dual shock setup in the rear (which I think you are doing), then you want that subframe to be very solid.  That's kind of independent of the increase in power, unlike the main frame, headstock, and swingarm.
Using the engine as a stressed member is a very good idea IMO, but that frame is gonna make me nervous until I see some X's and gussets on it.
Offline Mercuno
« Reply #106 on: December 23, 2011, 01:14:41 pm »
Just put down the first layer today, nothin else.
I will have to wait till it dries in this cold weather to see if it will slide on and off smoothly or if I will have to tweak it before layin it on thick.
Soon as the tank is done will start strengthening the frame and then on to wiring. I can feel it coming to life now. A whole lot more than when I cut the bike to pieces for sure lol.
Offline 65Ch3v3LL3
« Reply #107 on: December 23, 2011, 07:20:50 pm »
Just a thought here but if you are forming the tank to the frame then perhaps you should add the additional bracing and tubes first so you aren't having to redo your work. I agree with others here you need more tubing and gussets. I think a tubing bender would be a good purchase at this point. Good luck with the build.
1979 CB650
2011 Harley Road King
2008 Harley V-Rod VRSC DX
2012 Sierra Denali 2500HD
1965 Chevelle Malibu SS
1922 Ford T-Model
Offline Killer Canary
  • Typical Bran Muffin
« Reply #108 on: December 25, 2011, 05:24:33 pm »
Check out the latest issue of CMM; in the Show Us Yours section there's a CBR600 engine built up into a chopper.The mounts to the frame look pretty neat.
Kawi GPz900, H1
Offline Blackandsilver
  • dont forget the joker
  • Motorcycles kill brain cells
    • 76 cb750
« Reply #109 on: December 26, 2011, 01:04:22 am »
Subscribed!!! I gotta show my buddy Murray this!
Win some lose some, it's all the same to me.
I will never die
Offline Roach Carver
« Reply #110 on: December 26, 2011, 08:32:46 am »
Youtube the first ride for sure.
Offline ivanhoew
« Reply #111 on: December 26, 2011, 10:03:18 am »
most interesting ,thank you .
just do it .
Offline Mercuno
« Reply #112 on: December 30, 2011, 03:19:09 pm »
Not much done. I bought some 3 dollar foam in a can(s) lettin it dry overnight then gonna form it and start layin more glass...
Offline Syscrush
  • Sold. :(
« Reply #113 on: December 30, 2011, 10:08:03 pm »
Have you used that stuff for fiberglass fabbing before?  I have, and I found I had better luck using foam that sands easier.  I also prefer just building something up out of papier mache over that spray foam: It's hard outside and has big air gaps inside, I find it tough to work.
« Reply #114 on: December 31, 2011, 05:22:43 am »
I would just glass over that and have it painted like a funnel cake.
« Reply #115 on: December 31, 2011, 05:25:20 am »
I'd put a couple of eyes and a cute pink nose on it and call it a sheep! ;D
Offline Mercuno
« Reply #116 on: December 31, 2011, 07:35:32 am »
it could be frankenstein's brain
Offline Godffery
  • Godffery's Garage
« Reply #117 on: December 31, 2011, 08:32:23 am »
Hummm... not sure that's ever coming off the frame?  Looked like you had some substantial undercuts in the fiberglass part?
I have to say; this project has got me thinking!  8-\
« Reply #118 on: December 31, 2011, 08:56:51 am »
Always thinking about sheep, Terry!
Kawi GPz900, H1
Offline Tews19
  • I am no
« Reply #119 on: December 31, 2011, 09:24:54 am »
Hey Merc, i used the same spray foam for small leaks in the basement. That #$%* is extremely hard to remove. I wil continue to watch. Very interesting
1970 Honda CB750 survivor.
Offline Mercuno
« Reply #120 on: December 31, 2011, 01:10:55 pm »
Yeah I tried it while building my seat. I used masking tape and cooking spray over the bottom layer of glass. I want it in two pieces (top and bottom) so I can make final adjustments as needed before sealing it up. it will slide right off of there right now if I wanted it to. once it completely dries I will shape it and again mask and oil it before laying the top layer of glass.
As it sits right now I could shape it and then take it off of the bike completely to lay the glass so I could work on the motor wiring some more.
I should have mentioned about the undercut earlier: I tried to get it as form fitting as I could because as you know the glass has a tendency to sag if not supported. I was fortunate however as to not undercut, the base of the tank will slide on and off with ease. I also made it larger than necessary so I could cut it down one time and not need to add anymore glass. the bottom is a great success and I am very pleased with it. I now wish I had taken a picture of the cut down bottom before foaming the crap out of it haha.
When I am done shaping I will take some pics of it.
Fiberglass is a wonderful medium with a very small learning curve to it and I suggest giving it a try to anyone. thanks again for all of your support on this forum and please keep chiming in to help remind me of anything I may happen to miss.
I am also going to give my machine shop a call as the 76 sprocket just will not work. I will have one made with the 76 bolt holes and the 99 gears unless I can source something aftermarket?
« Reply #121 on: December 31, 2011, 09:06:44 pm »
Ha ha, I was waiting for that! ;D
Offline Godffery
  • Godffery's Garage
« Reply #122 on: January 01, 2012, 03:01:45 am »
Well that's good to here man; looking forward to seeing this come together.
Keep us posted on your progress.
Offline K5owner
« Reply #123 on: January 01, 2012, 03:28:19 am »
Interesting project - subscribed
-Ray
Remembering the past...   Livn' the dream
1975 Honda CB750 K5, Restored Aug/2011
1971 Honda CB175 K5, next project
1977 Honda CT70, swap meet scooter
2004 Honda NRX1800 (Rune), Cruiser
1977 Honda GL1000, daily driver
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #124 on: January 01, 2012, 07:09:51 am »
If you have trouble with the spray foam (it is bad to build with because it only has a rigid skin, and is full of soft airbubbles inside/ tough to bondo and sand..bla) been there tried that.
You can try the rigid foam insulation board, just cut and glue to size. Sands well. Even the green rigid foam they use at the florists works well.
There are 2 part urethane foam kits avail. The stuff that they make surfboards out of. You mix and pour, sand perfect, easy to work. Stuff is $$$ though.
