Author Topic: Carb inlet tee o-rings, CB750  (Read 4815 times)
Offline Magpie
« on: November 12, 2011, 04:59:08 PM »
Hi!
I've searched past threads for a suppplier of these and the threads are fairly old, I wonder if anyone has found a supplier of these at a reasonable price? They are 7.8 x 1.9 mm I believe and have been referred to as P-8 size JIS standard o-rings. Yamiya has these but a package of 10 will be about $30 shipped as a last resort.
I've called my local Honda shop, they are dicontinued at a price of $22 each, must be including the T.
I'll call around to the local equipement shops on Monday. I was hoping for a quick point me in the right direction.
Thanks, Cliff.
Offline sixthwisconsin
Re: Carb inlet tee o-rings, CB750
« Reply #1 on: November 12, 2011, 05:35:09 PM »
I went to my favorite hardware store and showed them both the old O ring and the Tee. I was asked if they were metric and they had them in stock. 73ยข ea and I thought that was way too much. I bought 10 of them and re-assembled the carbs (657b). They seemed to fit fine though I will not run the bike untill spring.
Offline Magpie
« Reply #2 on: November 12, 2011, 06:49:01 PM »
Too easy! Cliff.
Offline 70cbk0
« Reply #3 on: November 12, 2011, 07:15:28 PM »
I just found a big O-ring store in Toronto, they had the right size. Dirt cheap. They installed perfectly and I rode the bike all summer. It'll be easy since your in Canada. ABLE O RINGS 5511 STEELES AVE W. NORTH YORK (416)-741-0750.
1970 CB 750K0
1969 CB 750K0
1966 CB77 Superhawk
1982 Honda XR200R
Offline Magpie
« Reply #4 on: November 13, 2011, 07:27:55 AM »
Thanks for that! A friend has suggested 8 x 2 mm which is a more common size.
Cliff
Offline Magpie
« Reply #5 on: November 14, 2011, 11:48:25 AM »
I should learn to ask around my buds here before I trouble you guys. Got them at an industrial hose and fittings company at 15 cents each. Hondaman makes reference to these as 8x2 in his book so they should work.
Cliff
Offline horning88
  • Hound Dog
« Reply #6 on: February 05, 2012, 03:15:54 PM »
harbor freight has them in their metric kits the 397 piece kit has 18 of the 7.8mm x 1.9mm o-rings and i bought the kit for $9 and now will have any metric size ill ever need, also they have a 225 piece kit that has 10 of the 8mm x 2mm o-rings and that kit was also $9 i bought both kits just in case Almost forgot YES they do say they are petroleum/gas safe!
With my hobart in hand and a pile of scrap metal at my finger tips I feel I can rule the world!
« Reply #7 on: February 05, 2012, 03:26:32 PM »
I get them at lowes.  Not sure of the size, one that fits. The gas makes it swell and seal better.
Online CycleRanger
  • No comment about being an
« Reply #8 on: February 05, 2012, 03:54:15 PM »
These are still available from Honda as part of the carb gasket set.
PN
