Author Topic: Oh Lordy..I found a CBX. Shoot me!  (Read 82466 times)
Re: Oh Lordy..I found a CBX. Shoot me!
« Reply #250 on: August 30, 2012, 07:53:19 PM »
Toy - that motor looks incredible!  Hope you wont have to do that again.
« Reply #251 on: August 30, 2012, 08:09:20 PM »
Very nice! Just think, you have increased the value of the bike more than you have put into it and cosmetically it is on the high end of the value spectrum. The mechanical work has boosted it to anyone who has ever worked on one of these bikes or knows the value of the sweat equity and $$ you have put into it. It is going to be a great bike you will enjoy for many years and miles.  Take a complete set of detailed high resolution pictures to document all the work and condition of the bike. Definitely insure it for what its worth (stated value policy).
Offline toytuff
  • "watching the pinheads"
« Reply #252 on: August 31, 2012, 02:35:58 AM »
Thanks Steve-o! It turned out nice but I'm not sure how long the S-100 will last.
I have an old pic of the engine.
tt
Offline toytuff
« Reply #253 on: August 31, 2012, 02:44:06 AM »
Thank you for the compliment. I'm getting there slowly if it would just cool down. Great weather is right around the corner.  ;)
As far as value yes, it increased but more than that is the dependability. I have more in it then it's probably worth but the market is increasing on the 81/82 models. Price of 79/80 models are driving the price up on these.
I did a special order from Clearview shields so I'm waiting on that. Another oil filter cover is being done as the one I got arrived damaged. Once I get the rear of the bike done then flip it around on the lift and start on the front.  ;) New brakes, rebuild calipers, master cylinder, send the rotors to Michigan for a resurface, forks and tire.
tt
« Last Edit: August 31, 2012, 02:52:53 AM by toytuff »
Offline toytuff
« Reply #254 on: August 31, 2012, 08:51:31 AM »
After three (3) days an and estimated fourteen (14) hours of work this part is done. Waiting on parts is a killer of time.  ::)
Adjusted rear chain, bled the rear brake, installed oil cooler and lines and finished a few spots on the center stand with paint. Adjusted the brake pedal height a little more to my liking. Cleaned up the shop and wiped down the tools putting them where they belong.  8)
I'll concentrate on finishing up the fairing when the wind screen arrives and changing out the hardware on one saddlebag. All riveted in so it should be another challenge.  ;)
Hopefully by the end of September the weather will cool a bit and I'll start on the front.
tt
« Last Edit: August 31, 2012, 12:58:11 PM by toytuff »
Offline toytuff
« Reply #255 on: September 03, 2012, 12:42:27 PM »
More work today on the CBX. This was a lot of work because the exhaust is all one piece.  ::)
After installing new gaskets you have to guide the front and get the rear brackets somewhat close. They don't line up until you start to draw the exhaust in at the cylinder head. I did the left side first because of the side and center stand. Wrong!  :o
The right side was worse due to the fact of the crossover pipe, male end, has to slide into the left side which is a female end. Note to self..right side first next time.  ;)
Spent about one (1) hour or better on each pipe using various cleaning products. Had to "nip it in the bud" on reproduction exhaust due to "cost overruns" and a shrinking budget.
On we go but at least it's in the right direction now.
tt
« Reply #256 on: September 03, 2012, 01:12:03 PM »
Toy - that motor simply amazes me, absolutely beautiful!
BTW, is that a Handy Lift? I have been thinkin of gettin one.
Offline toytuff
« Reply #257 on: September 03, 2012, 01:23:38 PM »
It's about time you get a CBX isn't it? I gaze at the motor quite often. It's quite a bit of engineering to say the least. A little more complicated than a SOHC so work goes slower.
No, that is a lift from Harbor Freight. Mikki got me that for Christmas in 2010. Best gift I could receive. Look in the back of magazines and you can pick the foot model up for $299.00. The air assist models are more but you have the option of side mounts for a bigger area. I had to build side ramps for this one but it's  8)
tt
« Last Edit: September 03, 2012, 05:37:19 PM by toytuff »
Offline Dave K
« Reply #258 on: September 03, 2012, 02:18:20 PM »
This is not the air assist lift? Any complaints on the Harbor Freight lift? I HAVE to get a lift!
Your thread on this bike is NOT doing me any favors. I need to have one again, even if all I can do is look at it.
« Reply #259 on: September 03, 2012, 02:25:12 PM »
No, it is hydraulic, foot operated. My buddy has one that is air assist and he said it is not necessary.
On sale now for $419....
http://www.harborfreight.com/1000-lb-capacity-atvmotorcycle-lift-68892.html
Offline toytuff
« Reply #260 on: September 03, 2012, 02:28:26 PM »
Yes, that is what I meant to say. Geesih!
You can buy them for $299.00. I might have a coupon if you need it. The chock is useless.
tt
Offline toytuff
« Reply #261 on: September 03, 2012, 02:34:02 PM »
From gas tanks to motorcycle lifts I got your back Steve-o.  ;)
tt
« Reply #262 on: September 03, 2012, 02:40:10 PM »
I just found one in the back of my Motorcycle Classics mag, thanks.
Offline toytuff
« Reply #263 on: September 03, 2012, 02:42:57 PM »
Ok,ok..my mistake!  ;D
By all means I have loved this lift. There are better ones but for me it's been a life/back saver. Wish I had this when building my Hayabusa.  ;)
Just go buy one! Jag might sell his 82, not doing anything to it. Yet. Just go get one. You will never regret it.  8)
tt
Offline toytuff
« Reply #264 on: September 03, 2012, 02:44:24 PM »
There ya go!
Anything else I can help you with today? Customer service is number 1!
tt
« Reply #265 on: September 03, 2012, 02:46:18 PM »
There ya go!
tt
Got a rust free tank for a 550?!
Offline toytuff
« Reply #266 on: September 03, 2012, 02:48:01 PM »
For a 500 I do. Forum member had a 550 tank for board donation in classifieds.
tt
« Last Edit: September 03, 2012, 02:50:44 PM by toytuff »
Offline jaguar
« Reply #267 on: September 03, 2012, 03:05:14 PM »
tt
That cuts deep...lol
It is true that I have not done that much to/with it in a while.  Been running around alot, riding the 450 and just trying to enjoy my summer before getting back into the swing of school, I am finishing up my aerospace engineering degree.
Offline toytuff
« Reply #268 on: September 03, 2012, 03:07:11 PM »
tt
No offense meant jag!
I know your "hot" for a twin shock. Heck, I might buy another CBX myself.  ;)
tt
Offline jaguar
« Reply #269 on: September 03, 2012, 03:08:55 PM »
Just messing with you.
Yeah?  Another one?
Offline toytuff
« Reply #270 on: September 03, 2012, 03:13:09 PM »
Yeah?  Another one?
1979/1980 model. Can't have to many.  ;D
tt
Offline jaguar
« Reply #271 on: September 03, 2012, 03:24:05 PM »
Very jealous
Offline toytuff
« Reply #272 on: September 03, 2012, 03:27:02 PM »
Very jealous
Oh, like your CBX wasn't a find! And your CB 450?
tt
Offline jaguar
« Reply #273 on: September 03, 2012, 03:33:59 PM »
Very true, but something about grass being greener or something...lol
Some times I think I like the hunt more then anything.
« Reply #274 on: September 03, 2012, 03:41:18 PM »
I love the hunt!   And an occasional sle too...
