Author Topic: Worth the $ to bump compression from 9 to 10.5?  (Read 2249 times)
Offline eworth
« on: November 13, 2011, 08:13:12 AM »
Hey all,
Here's where my project stands and I'm interested in all your opinions on whether the next step is a waste of money.
1977 CB550F.  CB650 Cam,  Heads ported and matched to the intakes, 4-1 Jardine exhaust and Dyno S ignition.
The top end is apart and the above is just about done (Head will be back soon)
How much extra "Kick" am I going to get buying the Dynoman 592cc pistons / 61mm bore??
Is it worth the $800 or so dollars for the kit and cylinder work to make it happen?
How much difference should I expect in horsepower going up to the 592 from the improvements above that already been made?
Is this a waste of money or would there be a significant boost in hp and torque?
Thanks all,
Mark
Re: Worth the $ to bump compression from 9 to 10.5?
« Reply #1 on: November 13, 2011, 11:49:48 AM »
with the crappy fuel you get in the states i wouldnt go high with the compression.
« Reply #2 on: November 13, 2011, 11:56:33 AM »
I wouldn't do it, not worth the cost.
By the way, are you planning any suspension or brake improvements?
Offline luap
  • LAWL
« Reply #3 on: November 13, 2011, 12:10:30 PM »
looking at those last night on that website your 650 wont work, you also need to buy the cam he sell another what 250 bucks an then I believe the stock valves wont "work" either another 80 bucks an then the stock retainers wont  work again need the machines stainless ones he sells for 180 bucks, seems like one works off the other
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline eworth
« Reply #4 on: November 13, 2011, 12:17:49 PM »
Thanks Daven and Steve-O.      Had been on the fence and then started second guessing my decision to go through with it.
Steve-O.   Front brake rotor drilled, rebuilt caliper, new pads and new upgraded master cylinder and SS lines.   Rear is stock.
I'm thinking just the 650 cam and headwork will be a nice boost.     ;D
« Reply #5 on: November 13, 2011, 02:38:10 PM »
Let me offer this, take from it what you will. Someone here years ago planned to increase the power of his fairly low mileage 550 and ran it on the dyno first...36.8rwhp. I never saw that he returned with an "after" report.
I did up a 592 with 10.1:1CR, matched the inlet tracts plus did some mild porting, added a WebCam 58a, modified the cam sprocket then degreed the cam. It uses the stock PD carbs plus the air plenum (no box) with a single large K&N. It has a 4-1 also. The result is 51rwhp, a 28% increase in this case.
To just install a bigger bore without cam and/or head work will not live up to the power expectations. As an alternative, to tidy up ports with a different cam may deliver similar power to that bore increase alone.
There is an immediately obvious synergy improving the whole package, and done correctly, I don't believe you'll experience any problems at 10.5:1. However if there are wallet constraints, then I think you've followed the best path for the buck.  ;D
Offline eworth
« Reply #6 on: November 13, 2011, 02:50:53 PM »
BWALLER:
Your reply is really appreciated. Thanks. To this point, headwork, port match, 4-1, Dyna S and CB650 cam will be a nice improvement.  Glad I chose well.
Sounds like our set ups are similar except for compression and bore size increase.
I'll never race this engine but did want a bit more "uummmphh" out of her.     Maybe I'll just put her back together and see how it feels.     Can always do the 592cc upgrade down the road if I'm not satisfied in the current set up.
Cheers, Mark
« Reply #7 on: November 13, 2011, 03:19:21 PM »
Or sell and upgrade to an 836!  (that's what I did)
Offline eworth
« Reply #8 on: November 13, 2011, 03:39:04 PM »
oooooooo, tempting........ but I love my CB550.    ;D
« Reply #9 on: November 13, 2011, 03:49:26 PM »
And I miss my 550F. Will probably sell my K4 (not the 836) when I find a 550 that I have to have!
Offline eworth
« Reply #10 on: November 13, 2011, 03:55:01 PM »
They just nice little engines and they sound great too!!
Offline Rgconner
« Reply #11 on: November 14, 2011, 07:52:27 AM »
Might want to check out some of the recent posts about DynaS and problems with wiring:
http://forums.sohc4.net/index.php?topic=98305.0
and failures:
http://forums.sohc4.net/index.php?topic=98483.0
There are several other ignition options available, some made by members of the forums.
1975 CB550K aka "Grease Monkey"
Offline eworth
« Reply #12 on: November 14, 2011, 08:59:14 AM »
I've run the Dyna S since  April.  No problems yet.  But thanks I wlll check out the posts  you mentioned.
