Author Topic: Need to take off wheels, what to do to stabilize bike while they are off?  (Read 4868 times)
Offline Vreihenmotor6
hey guys, I've got the motor running nicely on my new to me 76 750f
now its time to adress the brakes and do some polishing/ cleaning of the fork legs and wheels
I think I'll be taking the front wheel off first, then later i'll take the rear off when I'm done with the front
whats the best way to stabilize the bike with no front wheel?
I have the factory center stand
thanks guys
Offline Artf0rm
Re: Need to take off wheels, what to do to stabilize bike while they are off?
« Reply #1 on: November 15, 2011, 06:47:46 AM »
$99 bucks.  And good for all kinds of things that will come down the road.  Get that and some ratchet straps and your bike won't go anywhere you don't want it to go.
http://www.harborfreight.com/1500-lb-capacity-atv-motorcycle-lift-2792.html
« Reply #2 on: November 15, 2011, 06:50:13 AM »
+1 on a jack, safest way to work on your bike. Check your local CL, I see them for sale regularly for as low as $50.
Offline shizzomynizzo
  • It's 5 o'clock somewhere
« Reply #3 on: November 15, 2011, 07:16:19 AM »
Best tool i bought for the bike besides the impact driver. Harbor freight has them on sale for 60 all the time
1974 CB550
1985 XLX Last of the IH
2001 Street Glide
Offline CycleRanger
  • No comment about being an
« Reply #4 on: November 15, 2011, 07:16:34 AM »
Just stick a cinder block and some 2x4 ends under the forks...
Don't over-think it. ;)
« Reply #5 on: November 15, 2011, 07:28:30 AM »
I lift it with come along and support with blocks and wood.
« Reply #6 on: November 15, 2011, 07:32:30 AM »
A small Hydro jack or other with a small block of wood under the oil filter or engine will stabilize and allow you to raise a little higher. Don't need to spend money,the centerstands work well.
Offline raymond10078
  • Just learnin' as I go . . . .
« Reply #7 on: November 15, 2011, 07:48:05 AM »
If put a 2x4 under the centerstand, then I just use a jack to raise the front end until the rear tire just touches, or I have enough clearance.  I need the 2x4 or else the rear tire touches before I have enough clearance (for the front tire/fender).
On one bike I have an ugly engine guard - that I'll put regular jack stands under as well.
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline Artf0rm
« Reply #8 on: November 15, 2011, 07:50:31 AM »
Good call Stev-o
Vreihen, go forth and buy used:
http://boston.craigslist.org/nwb/mcy/2693984640.html
Offline mono
  • Definitely no
« Reply #9 on: November 15, 2011, 08:50:41 AM »
hahaha --- since you guys mentioned checking CL for $50 bike jacks, i just did and there's one in town for sale for $50!  i'm picking it up tonight.  i guess wisdom = learning from others!  i love this forum.
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #10 on: November 15, 2011, 01:22:13 PM »
A stack of 2x4 lumber under the frame rails will work also and is cheaper.  Go for the lift at $50, and BTW, offer $30, the seals wear out and they leak down over time.  Don't rely on the hydraulics to hold the bike, use the lock bar.
Offline Gordon
  • 750K1, 550K2
« Reply #11 on: November 15, 2011, 03:27:06 PM »
A motorcycle jack works, as do many other temporary and readily available (free) options.  When making a purchase of this sort, think about how many times it will be needed versus the cost and the space available for storage of it.
I've rebuilt several bikes with only a floor jack and a piece of wood to hold the wheels off the ground.  If you'll need to be able to move the bike around while the wheels are off, then a motorcycle jack is the way to go.  If not, a standard floor jack and a piece of wood is all you need.
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #12 on: November 15, 2011, 05:21:02 PM »
I'm in the "Thrifty" group with the piece of wood with a vee cut in it for under frame support. It works excellent when the front wheel is needed off the floor surface. IE=that a SOHC owner would call "Monthly Maintenance"  ;)
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline luap
  • LAWL
« Reply #13 on: November 15, 2011, 06:36:14 PM »
hole in the ceiling with a ratchet strap looped over the truse looped around the neck, an another looped around the seat up to the one around the trus
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
« Reply #14 on: November 15, 2011, 07:50:19 PM »
thanks guys, I'm gonna try with the wood / jack stands, I'll post back how it goes, I'd rather not take the exhaust off again, but we'll see how much space there is
Offline mono
  • Definitely no
« Reply #15 on: November 15, 2011, 09:11:11 PM »
ok guys i need some advice - i got my bike jack tonight but it's got a crossbar support smack in the middle between the 2 "lifting arms" that my oil pan will hit.   i've got everything off the bike except for the front end and the engine, and my goal is to lift the bike to remove the front wheel/forks/etc. so it's a frame with an engine.
the "hanging it from the rafters" suggestion is awesome.  wish i hadn't gotten rid of the 1/2 ton chain hoist i used to have :/   oh, but this was before i decided to become a garage monkey.
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
« Reply #16 on: November 15, 2011, 09:15:56 PM »
Count me as a FORMER proponent (along with all my fellow cheap sh*ts) of the 2x4's under the frame rails to save a buck or two. Here's what happens if Murphy's Law strikes. Get the jack.
« Reply #17 on: November 15, 2011, 09:22:52 PM »
Mono - put a couple 2x4's on your jack.
Offline bjatwood
  • 1973 CB750-K3
« Reply #18 on: November 16, 2011, 05:25:18 AM »
Coach, what is that yellow jack looking thing under the Blue tarp? Could that be a "JACK"?!?!?!
Brian
#24193
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #19 on: November 16, 2011, 05:42:36 AM »
I got my jack for Christmas from Sears about 5 years ago.  I use it all the time.  That being said, I see no reason for a bike to spontaneously fall off of a small stack of properly placed 2x4 boards.  I use that method also, when my jack is serving another bike.  No more chance of that than the seals in the hydraulic jack failing (even slowly) and dumping the bike on the floor while it is unattended.  Always use the locking bar on floor jacks, always use jack stands under a vehicle, and never trust hydraulics.  never.
Offline CycleRanger
« Reply #20 on: November 16, 2011, 07:08:46 AM »
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #21 on: November 16, 2011, 07:57:03 AM »
Whats a ROFL?
Offline heffay
« Reply #22 on: November 16, 2011, 08:03:35 AM »
Rolling On Floor Laughing = ROFL
There's also roflmao or roflmfao etc
Offline HondanutRider
« Reply #23 on: November 16, 2011, 08:22:49 AM »
Actually, that is a very nice solution.  Another way to achieve the same is with an engine hoist.  They can be made to act like a crane, and as such it is possible to hang a bike with straps from it and hold it in the air while removing the wheels.  The engine hoists usually also have wheels, making it easy to move the suspended bike around.  I have a motorcycle lift like the Harbor Freight described, and I actually prefer using the engine hoist.  I recently used the hoist on the front only of a bike while I removed the forks to replace the seals.
Offline heffay
« Reply #24 on: November 16, 2011, 08:54:12 AM »
I didn't want to post these, but after the jack-off pictures I'm reminded that we all do silly things.  At least mine didn't end up with the bike on the ground.   ;D
the 2x4 rigging was only there as a prop in case the weld on the clothes line post gave way.  It was super strong though, it didn't even move or creak.  I think I was being overly cautious, but had I not done it, I'm sure it would have come crashing down.
