Author Topic: Society for the Prevention of Cruelty to Motorcycles: Annual Appeal (the C.L. mo  (Read 2193 times)
Offline 78whiteorbs
This guy has a classics shop were he actually teaches people to work on vintage bikes- Pretty cool fella posted this :
Greetings fellow motorcycle owners,
Do the right thing for your two-wheeled companion - do a few simple and inexpensive things now so that your bike is ready to ride on the first great day of spring.
Or you could wait until that first warm day only to find that your battery is dead, the fuel in the tank gone bad, the carbs gummed up from sitting full of untreated fuel for months, the chain rusty and the sprockets shot - and every bike shop in the known world is booked for weeks out with work for other lazy-ass motorcycle abusers just like you. Is there really a choice?
So here's what you do:
A. Take your bike to one of the several shops in the area for a winter-storage prep.
B. Do it yourself.
Either way, this is what should be done.
Have the following material ready to hand:
Oil and filter
Stabil brand fuel treatment
Cable lube
Chain lube
Fork oil
Cleaners and polish
1.) Ride your bike until you have to switch to Reserve.
2.) Add the specified amount of Stabil to your fuel tank for its capacity - directions on the back of the Stabil bottle
3.) Fill the tank to the brim and ride it for five miles or so - enough to ensure that the fuel in the carbs is treated fuel.
4.) Top up the tank.
5.) While the engine is still hot/warm from your ride, change the oil and filter.
Change transmission oil if separate from the engine oil - shaft-drive oil too if you have one.
6. Clean/lube/adjust the chain.
7.) Pinch the chain between your fingers at the 3 o'clock position on the rear sprocket.
If you can pull it more than 1/3 the way up off the tooth, the chain is stretched and will only trash your sprockets if they are still good - which they probably are not.
The teeth on the sprockets should be symmetrical - not worn more on one side than the other or hooked. The ends of the teeth should be squared off - not pointy.
You will need to remove the front/countershaft sprocket cover to examine the teeth.
Worn sprockets will trash a good chain and versa vice. Ideally, they are replaced as a complete set - chain and sprockets.
8.) Replace the chain and/or sprockets as necessary.
9.) Examine your brake pads/shoes - replace if worn.
10.) Replace brake fluid.
11.) Flush and change coolant - if your bike is a water-pumper.
12.) Drain and replace the hydraulic fluid in the front forks. Consult your manual for the right type and amount.
13. Replace the fork seals at the same time if there is any evidence of weepage.
14. Remove all the control cables. Using a pressure luber, run cleaner and then lube through them. Replace and adjust.
15.) Change/clean the air filter.
16.) Replace the tires if worn more than 1/2 way.
17. Remove the battery and marry it to a trickle/float charger someplace that does not freeze.
18. Clean and polish your bike. Clean/treat plastic/rubber with Armor-All.
19. Put it on its center-stand or some other stand - take the weight of the bike off the springs and the tires' contact patches.
20. Cover it with a dust sheet if stored inside - the best cover you can afford if outside.
21. If the bike is to be stored outside or in an unheated garage/shed, spray the whole thing down with WD-40 or some such to prevent condensation corrosion.
In the spring, spray it down with a cycle cleaner like SS-100 and hose off.
Now for the pay-off.
On that first day of spring, install your battery, turn the key, and go riding.
This public service announcement is brought to you by Existential Motorcycles on behalf of all the WNC motorcycle shops.
Chris Finlayson
Alexander, NC 28701
TEL: 828-683-9289
Offline kerryb
  • Not a very
Dear Whiteorbs,
Thank you for taking the time to re-write this so I can reference it easily as a checklist for putting my bikes away.
Sincerely,
Kerry
« Last Edit: November 17, 2011, 04:37:09 AM by kerryb »
Offline Rigid
  • She likes a
    • KingCustomCycles
I just ride year around, and take care of these things as needed.  It is a tall order during an Indiana Winter but we seldom see more than 3 weeks without some sunshine and dry roads. Changing the oil in the Fall is especially important, condensation and sediment form acids in the oil that can attack engine internal parts.
Offline 78whiteorbs
Dear Whiteorbs,
Sincerely,
Kerry
my pleasure brother- always happy to share valuable information with others,especially those who appreciate it !
« Last Edit: November 17, 2011, 09:24:11 AM by 78whiteorbs »
Offline Duanob
  • Bold Timer
  • Gotcha!
On the subject of fuel stabilizers:
I found a new product by Stabil for marine engines I tried out this year in my boat. It's supposed to prevent the negative effects of alcohol in gasoline. It never had that before. I might try it in my bike tank and see if I get the white powder crud build up again.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline 78whiteorbs
Is that for two stroke engines?
Not so sure about the Armor all but agreed.
Offline WarwickE36
Is there any sense in fogging the cylinders like you would a 2cycle boat?  I thought about pulling the plugs and fogging it a bit then replacing the plugs.  Good, Bad, Total Nonsense?
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline Rigid
  • She likes a
    • KingCustomCycles
Couldn't hurt, especially on a low mileage engine that has not built up a layer of protective internal varnish.  Areas around heavy industry and coastal areas are the worst for corrosion.
Offline WarwickE36
Im literally right on the coast, enough so that brake rotors flash rust if sitting for a couple days.  A fogging I will go.
2004 SV650s
Your stainless rotors are rusting..?
72500john
great post!! was needing a checklist to store by bike for the winter!
thanks!
Offline Johnie
Am I the only one who uses Stabil and also drains the carbs for winter? I did not see that in the original post.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline WarwickE36
The rotors on my car will get a bit of surface rust if not driven for a few days.  It kicks off with the first stop, nothing major but it is there. Never noticed it on the bike (which sits for longer period of time ironically.) I live about 30 seconds from the Ocean.  Salt is evil.
2004 SV650s
Offline Duanob
  • Bold Timer
  • Gotcha!
Nope I do it to. For all my vehicles that sit through the winter. But I found that regular Stabil didn't do shyte for the alcohol in hte fuel. Still leaves a residue to clog small jets.
« Last Edit: November 18, 2011, 09:17:40 AM by Duanob »
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline Johnie
Agreed...I just can not let my jets sit in fuel all winter...Stabil or not.
Oshkosh, WI  USA
Offline WarwickE36
RetroRocket.... this is what I'm getting at ....
Car's been sitting 5 days at my work, Not cheap rotors either.  Napa Ultra-Premiums
2004 SV650s
How dare you talk cages in a "prevention of cruelty of bikes" thread, They are the main cause of "cruelty" to our poor old bikes.... :P ;D ;)
Offline WarwickE36
Haha, point taken Retro... But our riding season is coming to a close here in Maine.  We've been lucky its been in the 60's this month.  Normally it would be in the 30's and riding would be over.  Shall I start a global warming/ oil thread  :o ::)
2004 SV650s
 ;D Throw in dyna beads and hang on..... ;D :o
Offline 4n2twstr
Quick question for the experts- can I drain oil but not replace it till Spring time or will that be even worse than leaving it? The oil that's in it now is only about 400mi.
Leave the oil in, especially if its only done 400 miles...
I used Stabil for the first time this year, and am impressed with the stuff. My Suzuki GS1000 with high comp Yoshimura pistons is especially susceptible to "flat" gas, and my Triumph Rocket III and CB750's aren't all that far behind it. After sitting for at least 8 months, (I can't remember when I last rode it) it fired right up and a short ride showed that it was happy to rev right through the RPM range. Good stuff, in previous years I've had to drain the foul smelling 'flat' gas and throw it on the weeds. Cheers, Terry. ;D
