Author Topic: EMP proof cb750?  (Read 831 times)
Offline tanman855
EMP proof cb750?
« on: November 17, 2011, 02:00:14 PM »
Does anybody know how we could make our simple carburated motorcycles emp(electro magnetic pulse) resistant/proof?
1974 cb750 (cafe in progress)
Offline Coyote13
Re: EMP proof cb750?
« Reply #1 on: November 17, 2011, 02:00:57 PM »
Have you been reading the APOCOLYPSE thread?
'78 CB750K.  Throttle ripper.
'71 CB100.  Grocery getter.
'01 XL883.  Panty dropper. Gone but not forgotten.
Offline tanman855
« Reply #2 on: November 17, 2011, 02:08:14 PM »
Maybe.... ::)
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: November 17, 2011, 02:09:57 PM »
Build it its own little Faraday Cage. However, I think we will have bigger problems than our beloved bikes.  ;)
« Reply #4 on: November 17, 2011, 02:32:12 PM »
EMP screws up silicon junctions.  The only ones in the stock bike are in the rectifier, and with some models the neutral light circuit.  So, you'd need a cage/sheild around that.  And shield the electrical wiring to it, as well.
If you have electronic ignition, the silicon in that can fry.  So, either dump that, or have a points plate spare to slap on after it quits.
Mostly you have to keep the wiring shielded so the pulse can't generate a voltage within the signal or power carrying wires.
« Reply #5 on: November 18, 2011, 03:11:59 PM »
I tested some metals once and steel seemed to shield EMP's best due to it's magnetic properties. Like the distributor shield on an older vette. Tin foil made of real tin?
Offline 74cb750
« Reply #6 on: November 18, 2011, 04:59:35 PM »
I'm all set up with my own tin hat to keep out the EMP's.
Laugh at least once a day.
Life  $ucks, then you die.
