Author Topic: quick chain sprocket question  (Read 951 times)
Offline Eddie
« on: November 18, 2011, 04:41:30 PM »
I have a CB550 with 15k miles on it and have extended the swing arm 2"....so I need to get a new chain. Should I change the sprockets? The chain is a DID 520....both chain and sprockets are in excellent shape.
Offline lone*X
Re: quick chain sprocket question
« Reply #1 on: November 18, 2011, 05:23:37 PM »
A lot of guys are going to tell you that you should change the sprockets and chain as a set but in reality I usually do it every other chain swap. The amount of wear they get depends a lot on the quality of maintenance and the way the bike is ridden.  You say the sprockets are in excellent condition, then why would you want to change them?  If you are questioning your diagnosis of their condition post a close up photo and I sure there will be lots of comments.
520 sprockets and chain are not stock so these have already been changed at some point.  Stock was 530.
« Last Edit: November 18, 2011, 05:25:45 PM by lone*X »
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline Eddie
« Reply #2 on: November 18, 2011, 05:40:30 PM »
I'll post a pic tomorrow....my bad..typo...  it is a 530. thanks for the help
Offline grcamna2
« Reply #3 on: November 18, 2011, 09:05:07 PM »
Clean out the area of the sprocket teeth Real well before posting the pics & take some close ups...carb cleaner works good.
Offline Eddie
« Reply #4 on: November 19, 2011, 06:36:58 AM »
Here's the pics
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #5 on: November 19, 2011, 06:58:27 AM »
Those sprockets look brand new! Thow another 530 chain on it and ride on!
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline Eddie
« Reply #6 on: November 19, 2011, 09:00:07 AM »
Anybody know about the brand of chain called Sapphire...supposedly made under "the watchful eye" of Diamond ?
Offline Deltarider
« Reply #7 on: November 20, 2011, 05:37:12 AM »
So do I. Those sprockets are fine for another chain, btw.
CB500K2-ED Excel black
