Author Topic: cracked stand pipes  (Read 1243 times)
Offline dusterdude
cracked stand pipes
« on: November 20, 2011, 05:47:19 AM »
does anyone know of a gas resistant sealant that can be used to seal cracked standpipes or perhaps another method of achieving the same thing.thanks
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Re: cracked stand pipes
« Reply #1 on: November 20, 2011, 06:05:09 AM »
Give this stuff a try-it really works and is cheap.   http://www.totalmotorcycle.com/reviews/SealAllGlueReview.htm
« Reply #2 on: November 20, 2011, 06:17:58 AM »
Small plumbers torch and solder
Offline grcamna2
« Reply #3 on: November 20, 2011, 08:08:22 AM »
I've used JBweld and it is still holding.
Offline dusterdude
« Reply #4 on: November 20, 2011, 12:41:02 PM »
good replies and i thank all of you.first,i had jb weld on them and the gas ate it up,so i dont want to do that again.i had a friend of mine try solder and he said it wouldnt stick,now ek,i have seal all and am in the process of trying it,ill let you guys know how it turns out.thanks again
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #5 on: November 20, 2011, 12:45:17 PM »
+1 on the solder, clean it well, I use sandpaper and a small soldering iron.  Permanent fix as far as I can tell.
« Reply #6 on: November 20, 2011, 12:53:16 PM »
Sand it a little also before the Seal All and let it dry well but I think you may be surprised.Fixed a cracked carb body by an emulsion tube a very,very long time ago and as far as I know its still hanging in there.
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #7 on: November 20, 2011, 03:50:04 PM »
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline dusterdude
« Reply #8 on: November 20, 2011, 04:30:19 PM »
thanks frosty,the heat shrink sounds pretty good,ill see if the seal all works first
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
