Author Topic: Neutral/starter safety switch not work when cold?  (Read 1554 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: November 22, 2011, 11:01:10 AM »
A buddy of mine has a 400A which I know isn't sohc/4.....
BUT, it has that safety switch on it that doesn't allow you to start it "in gear" - just like the 750A. Has anyone ever had problems with the switch "thinking" that the bike is in 1 or 2 when in fact it's in N? And therefore it won't let you start the bike?
I ask because his bike runs great. Starts easy when it's warm outside. But when the temps drop below 45 or so, he has to pour hot water onto the engine - near the back by the transmission - and that seems to fix the problem. Weird.
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
Re: Neutral/starter safety switch not work when cold?
« Reply #1 on: November 23, 2011, 06:02:31 AM »
Nope - don't have this problem with my sohc/2.
I would pull the switch, and make sure the plunger travels easily.  It may be gummed up with old oil/sludge.
You'll have to located and disconnect the two connectors - but that would be my first step.
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
