Yeah typically I don't buy anything because I like my projects to progress as cheaply as possible, but I have a huge shed full of old motorcycle parts, with tons of coils lying around. Considering that you'd think I know a thing or two about points, but in fact this is only the 2nd points system I have ever worked on, the first was on my hondamatic and I just swapped out the old points plate because it was completely sized with rust. Anyways last night was fruitful, I did a series of good experiments which led me to believe that the cause of the problem was corrosion on the 2-3 points set. Confirmed, now we have spark albeit weak, so I am off to restore and replace a lot of the crappy wiring from the previous owner: lampwire, speaker wire, solderless connectors, etc.
Many thanks to all
