Author Topic: CB750 Rear wheels  (Read 1907 times)
Offline H2Eric
CB750 Rear wheels
« on: November 25, 2011, 07:56:36 AM »
I have a K3 frame and swinging arm, I also have a rear wheel which came out of a K7, which of course will not fit as the later swinging arms were wider at the rear. It's not just the spacers that are different as the K7 wheel will not center in the K3 swinging arm. Is it perchance that it's the sprocket carrier that's the issue here?
Some measurements
back of sprocket to flange
Depth of bearing housing to sprocket
If the earlier sprocket carriers are narrower and assuming that the cush drive is the same then providing I can find one perhaps I might be able to use the K7 hub with the K3
Any info gratefully received
Thanks
Eric
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
http://forums.sohc4.net/index.php/topic,94588.0.html
Growing old is mandatory, growing up is optional.
Offline Dyrden
Re: CB750 Rear wheels
« Reply #1 on: November 25, 2011, 08:39:58 AM »
I'm pretty sure the hubs are the same. The difference comes from the swinger, carrier and spacers.
Offline Patrick
« Reply #2 on: November 25, 2011, 09:25:10 AM »
Use the K3 spacers and sprocket carrier and you can easily mount a K7 wheel on a K3 swing arm. I've done it a couple times. It is more than just the fit in the swingarm at issue. using the wrong sprocket carrier will cause the chain not to line up correctly.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #3 on: November 25, 2011, 10:46:57 AM »
Patrick
Awesome!  I know this isn't my thread...I started one only to not get an answer.  Thanks Patrick!
Offline H2Eric
« Reply #4 on: November 25, 2011, 02:59:53 PM »
Thanks Patrick, I new somebody would have the answer on here.
Have a great weekend
Cheers
Eric
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
Offline mcuozzo
  • Bottle in front of me or frontal labotomy?
    • 77 CB750K - needs total rebuild
« Reply #5 on: November 25, 2011, 06:56:30 PM »
Well, you have your answer but yes it's the sprocket carrier that's wider.
Here's the difference, courtesy of cyclex:
http://www.cyclexchange.net/index%20pics/picture%206.JPG
Also K7/K8's use 630 chains so you need to use and earlier sprocket as your K3 has a 530 front sprocket.
You should be able to use stock K3 spacers, axles etc. to make it all work.  Basically by using an earlier sprocket and sprocket carrier you have a stock K3 hub.
Good luck!
Matt
