Author Topic: Throttle control  (Read 3604 times)
Offline tweakin
  • tear down
Throttle control
« on: November 25, 2011, 09:17:10 AM »
I am in the market for an aftermarket throttle control, preferably a quick twist.  What are you guys using?
Re: Throttle control
« Reply #1 on: November 25, 2011, 09:39:07 AM »
I'm using a throttle assembly from who knows what. It was attached to a set of Lectrons. It's about 100 degrees. I would like to have a spare pipe but can find one the same so will attempt to make one from alloy.
I do have a Tomasselli quick action (single cable) throttle if you're interested. That is if you can get around the single cable politics.  ;D
Offline turboguzzi
« Reply #2 on: November 25, 2011, 09:40:33 AM »
I use cagiva/ducati throttles in mine, but if you can afford it, any of the racing ones with changeable throttle pulleys are a nice idea.
http://www.euro-racing.it/Item.aspx?id=26#
Offline voxonda
« Reply #3 on: November 25, 2011, 10:20:04 AM »
I use a Japauto quick twist throttle on mine. 40 years old and still working great.
Offline tweakin
  • tear down
Throttle control
« Reply #4 on: November 25, 2011, 11:06:39 AM »
thanks bwaller but I want a push/pull throttle.
I really want a Robby Moto but will probably go with the motion pro.
Offline martin426
« Reply #5 on: November 26, 2011, 06:08:48 AM »
I use the Venhill 888 Fast Action push/pull throttle sets.  They are available through Venhill USA although not advertised on their website (www.venhillusa.com).
Scott
« Last Edit: November 26, 2011, 06:10:20 AM by martin426 »
1978 CB550
1970 CR750 replica
1979 RCB1000 replica
1988 RC31
Offline tweakin
  • tear down
« Reply #6 on: November 26, 2011, 06:21:44 AM »
I have not seen that one yet, thanks for sharing.
Scott
Offline nippon
    • Classic Cycle City
Offline somesuch
« Reply #9 on: November 26, 2011, 06:37:54 PM »
On my GSXR1000 I used an R1 throttle tube to make it quicker. Those are inexpensive new and even cheaper used.....plenty available too.
« Reply #10 on: November 26, 2011, 08:07:35 PM »
Tweakin are you using stock switch gear?
Offline tweakin
  • tear down
« Reply #11 on: November 27, 2011, 04:19:58 AM »
No, will not work with stock switch gear so I am upgrading the controls as well.
