Author Topic: Drilling Rotors  (Read 68284 times)
Offline Alan F.
Re: Anyone have a brake rotor drilling template?
« Reply #200 on: February 21, 2008, 05:48:13 AM »
736cc, you've got a PM.  that's a wild bike and I've got some wheel questions.
eldar
« Reply #201 on: February 21, 2008, 06:22:53 AM »
One comment I saw a while back said that it decreased initial braking action somewhat since there is less surface for the pad to contact. With dual disk, not much worry but those of us with the single might want to check on this.
Offline Jinxracing
  • It's hot shit, not
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #202 on: February 21, 2008, 03:28:04 PM »
Cribbed this from the brakewarehouse.com Brembo FAQ page...some interesting food for thought. Especially the part about rotors cracking when the hole edges aren't radiused or chamfered properly. Yikes!
I’ve heard that cross-drilled rotors are prone to cracking. Are cross-drilled rotors prone to problems?
Some people prefer slotted rotors because of problems that came about when cross-drilled rotors first came to market. At that time, quite frequently, the holes were drilled too large, penetrating the cooling vanes and were not radiused or chamfered. The end result was that the rotor lost its structural integrity and tended to crack, so slotted rotors were developed. They do help dissipate the hot gasses, but not to the same degree as cross-drilled, usually lowering operating temperatures about 100 degrees. We always recommend cross-drilled unless you are particularly concerned with structural integrity. In some cases, only slotted rotors are available.
–Captain Horatio Hornblower
www.thehairynickel.com
Offline Alan F.
« Reply #203 on: February 21, 2008, 07:39:36 PM »
Hey Swoop, that's because the template goes over the rotor hub...the side of the rotor that mounts to the wheel hub, that's why it looks opposite.  But whatever pattern you like best, it's YOUR bike, you get to choose.
Roscoe
Drilling out front and rear brake disks
« Reply #204 on: February 22, 2008, 06:49:38 PM »
Does anyone know how to drill out the front and rear disks? Is there a pattern you should use ? And what are the advantages of doing so apart from looking good? I'm new to this.
Are they easy to drill? Cheers, Roscoe
fuzzybutt
Re: Drilling out front and rear brake disks
« Reply #205 on: February 22, 2008, 07:04:55 PM »
you might want to try searching the forums before asking a question. there have been lots of threads devoted to this subject in the last couple of weeks
Roscoe
« Reply #206 on: February 22, 2008, 07:35:30 PM »
Sorry about that just though it might be qucker this way as there is so much info on the forum it could take a while finding it.
Offline kghost
« Reply #207 on: February 22, 2008, 08:56:41 PM »
I remember when fuzzybutt was a newbie......
Just teasing ya Jeff.
He's just reached a point where the questions about a topic thats been beat to death drives him nuts.
We all get there eventually.
There is literally volumes of information in various topics about drilling out damn rotors and drums.
Stranger in a strange land
fuzzybutt
« Reply #208 on: February 22, 2008, 10:39:06 PM »
sorry about that roscoe, ya just got me on a bad day  ;)  pain issues
Offline neil10
« Reply #209 on: February 22, 2008, 10:45:35 PM »
if u can't help keep quiet
Offline kghost
« Reply #210 on: February 22, 2008, 10:48:31 PM »
Said the guy with 100 posts....... :D ;D ;D ;D ;D ;D ;D
fuzzybutt
« Reply #211 on: February 22, 2008, 10:57:27 PM »
ahhhhhhhhhh it's all in good fun.
Offline Steve F
« Reply #212 on: February 23, 2008, 01:04:08 AM »
Try this link from a post just two or three days old....
http://forums.sohc4.net/index.php?topic=31083.0
Regards,
Offline joeb
« Reply #213 on: February 23, 2008, 07:24:13 AM »
Nice burn. kghost  ;D
Offline Godffery
  • Godffery's Garage
« Reply #214 on: February 23, 2008, 08:03:33 AM »
   I'll post a pattern I made as soon as I figure out how ?
http://springvinmoto.com/gallery/album85/Twin_Disc_1
Godffery
http://tinyurl.com/yoelqb
« Last Edit: February 23, 2008, 09:35:20 AM by Godffery »
Offline kghost
« Reply #215 on: February 23, 2008, 09:26:23 AM »
Two words....Cobalt drillbits.
If you use high speed steel...we'll see ya in a couple years.
When I do mine I use an old rotor as a pattern....long as the diameter matches its just a guide.
Drill two holes and bolt the pattern to your disk.
« Reply #216 on: February 23, 2008, 09:30:07 AM »
High speed will work under the right conditions.. go slow, use coolant..
Offline kghost
« Reply #217 on: February 23, 2008, 09:31:26 AM »
Use coolant, make a mess, take all day..... :D :D
Roscoe
« Reply #218 on: February 23, 2008, 01:49:12 PM »
Hey thanks guys for the help. No worries fuzzybutt. No offence taken. I'll let you know how I get on when I do it. Cheers and thanks again for the help. Roscoe
Offline turboguzzi
disc drilling pattern
« Reply #219 on: May 12, 2008, 01:25:55 PM »
Hello All
Would like to know if anybody's got a good and proven drilling pattern for front discs.
Bent one of the drilled/slotted suzuki discs I was running in my racer and manged to get only a non drilled replacement.
A dxf file would be best but can work it out also from dimensions/pics.
Thanks in advance
TG
Offline Kev Nemo
  • Honda Hacker
  • http://fallingapartart.com/
    • FallingApartArt
Pic request-Lightening holes, both aesthetic and functional
« Reply #220 on: May 23, 2008, 06:34:41 AM »
Just looking for ideas. Also methods would be a great help (traditional drill, drill press,etc.) My main question is getting different sizes and layouts. I've read a post on cross drilling calipers by using a CAD layout-is there a simpler method?
Destroyed by Design since 2009 http://fallingapartart.com/
- '78 CB750k bobtrack
Offline kghost
Re: Pic request-Lightening holes, both aesthetic and functional
« Reply #221 on: May 23, 2008, 08:32:09 AM »
Far as caliper drilling goes....
A flat worn out sport bike rotor of the appropriate diameter is what I used.
Drill the first two holes 180 degrees apart using the worn out rotor as a guide....
Bolt them together and drill all the rest.
Least thats what I do.....
No patterns...no guesswork...no line up problems...no wandering drill bits etc.
Offline Steve F
« Reply #222 on: May 23, 2008, 09:38:03 AM »
kghost, do you have a favorite drill bit (composition) that works best for you?  What RPM works best?
I'm obviously not KGHOST, but the drills I would recommend would be of the COBALT variety, and short.  The length I used is called a "screw machine length" or "SML" and are available from just about any industrial supply.  I used water soluble coolant and about 500 rpm on a 5/16 bit.  Smaller bits could tolerate a bit faster spindle speed.
Offline kghost
« Reply #223 on: May 23, 2008, 12:37:42 PM »
Steve has it...COBALT...anythink else is a waste of time and money.
Be prepared for sticker shock...but ya only buy one.
Offline chopstar500
  • King of the Nighttime World
« Reply #224 on: May 23, 2008, 02:36:16 PM »
I took measurements first, then did a full scale layout of the patterns in Microsoft Word (you can get very precise when you scale lines to the actual size) and then printed the patterns and applied them directly to the parts with some cheapo gluestick - then drilled the holes. I staggered the hole sizes (symetrically) and then finished them up with a chamfer bit.
Completed Project "Four Pack" - My 1971 CB500 KO - Now For Sale - email me for more info!
