Author Topic: Drilling Rotors  (Read 68257 times)
Re: Pic request-Lightening holes, both aesthetic and functional
« Reply #225 on: May 23, 2008, 09:25:55 PM »
The short series drills are allso known as stub drills or stub length, generally come in split points which helps, till you try to sharpen.
500 sounds fairly fast for a drill press w/o flood coolant, even a small decrease in speed can easily double life of a drill. I can get by drilling a stainless rotor with High Speed Steel drills, if using coolant.
once the drill is dull, nothing much will help except sharpening..
If you want to layout holes to drill ( not on the rotors) try this ancient method..layout die & dividers..
Offline Kev Nemo
  • Honda Hacker
  • http://fallingapartart.com/
    • FallingApartArt
« Reply #226 on: August 01, 2008, 06:55:40 AM »
I took measurements first, then did a full scale layout of the patterns in Microsoft Word (you can get very precise when you scale lines to the actual size) and then printed the patterns and applied them directly to the parts with some cheapo gluestick - then drilled the holes. I staggered the hole sizes (symetrically) and then finished them up with a chamfer bit.
What gauge flat stock did you use for the rear stabilzer bar? That's exactly what I'm thinking of doing.
Destroyed by Design since 2009 http://fallingapartart.com/
- '78 CB750k bobtrack
joeyboy
« Reply #227 on: August 01, 2008, 07:47:02 AM »
I accept criticizm for this question, but what do the lightening holes do?  They sure look really cool.
Offline Kev Nemo
  • Honda Hacker
    • FallingApartArt
« Reply #228 on: August 01, 2008, 07:48:42 AM »
Lighten stuff. ;)
joeyboy
« Reply #229 on: August 01, 2008, 08:08:30 AM »
Oh yeah, that makes sense.  But how much weight do you lose really?  It looks great, but functionality is in question on my behalf.  I am not doubting those who do it, just curious.
Offline Kev Nemo
  • Honda Hacker
    • FallingApartArt
« Reply #230 on: August 01, 2008, 08:29:26 AM »
You know, I'm not sure. There's a thread sticky for the CR's and I'm not seeing a ton of lightening holes there. Maybe someone with more info can fill us in.
Offline ajinreno
« Reply #231 on: August 01, 2008, 08:34:58 AM »
They are more aesthetic than anything else...don't really lose that much weight. If you really want to lighten your bike, start eating more salads and go to the gym.
Offline Tower
  • Only at conception could I have been called a
  • My personal time machine: 1973 CB750K3
« Reply #232 on: August 01, 2008, 08:48:52 AM »
drilling the brake disc helps prevent warpage and fading, dissipitates heat faster.
Offline KB02
« Reply #233 on: August 01, 2008, 09:49:05 AM »
Yeah, on a disk, the holes actually have a function. Otheerb than that, they look cool. Weight wise, you're really talking ounces unless you have so many hole in your bike that it looks like swiss cheese, then you might have save a pound or two and the bike might not be safe to ride. The theory, though, is an increased power to wieght ratio: The more power / the less weight the better.
Don't drill too many holes in your brakes, though, or you risk loosing enough braking area on the disk to acurately stop the bike.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
« Reply #234 on: August 01, 2008, 11:05:05 AM »
As tower mention drilling the front brake disk helps dissipate heat faster. Rear drum and sprocket cover holes are for looks only. However, drilling the rear drum (and front sprocket cover) has the potential to let in water leading to reduced braking performance on the rear...possible corrosion. Of course if you never ride it in the rain then thats not an issue.
cheers
Andy
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
« Reply #235 on: August 01, 2008, 11:19:07 AM »
500rpm is the maximum I run cobalts where I work. If you run them too fast the cutting edge can be easily ruined in an instant.
Offline pablo78cb550
  • mmmph.
« Reply #236 on: August 02, 2008, 10:56:20 PM »
the best i've seen.
Bikes in hand:
1977 Yamaha XS650
1978 Yamaha SR500 #119!
1978 Yamaha XS400
1978 Honda CB550K
1965 Ducati Monza 250
Sold off:
1992 Yamaha FZR600
1981 Yamaha Seca 550
Offline void909
« Reply #237 on: August 02, 2008, 11:43:15 PM »
Who did that and how?
knock with no answer
troppo
« Reply #238 on: August 02, 2008, 11:44:49 PM »
looks bloody good, looks like its been milled.
  • mmmph.
« Reply #239 on: August 03, 2008, 02:22:45 AM »
i can't remember. but one of the guys on here bought one for his bike on ebay.
but yeah, it's milled.
Bikes in hand:
1977 Yamaha XS650
1978 Yamaha XS400
1978 Honda CB550K
Sold off:
1992 Yamaha FZR600
Offline merc2dogs
« Reply #240 on: August 03, 2008, 07:59:54 AM »
Judging by the radial pattern in the middle, I'd have to say it was done on a CNC mill. The rest could be done on a regular mill, or on a good sturdy drill press with side cutter bits.
Ken.
Offline bradweingartner
  • 74 CB 550 x2
« Reply #241 on: August 03, 2008, 01:01:22 PM »
There is not radial pattern, those are reflections!
Offline CrisPDuk
  • Christ on a bike! Me, an
« Reply #242 on: August 03, 2008, 01:36:24 PM »
Damn and blast, I thought I'd finished with the polishing and machining, I'm definitely going to have to get my sprocket cover done like that 8)
1978 CB550 K3
1985 H100S
Offline eurban
« Reply #243 on: August 03, 2008, 01:56:39 PM »
The GL 1000 rotors on the front of my 78 750k have been significantly drilled.  They were actually an ebay score from years ago but they have been in service for over 3 years and work quite well with solid braking performance.  The holes reduce the weight of each rotor by about 1/3 . . . .
« Last Edit: August 03, 2008, 03:19:54 PM by eurban »
« Reply #244 on: August 03, 2008, 02:47:17 PM »
The GL 1000 rotors on the front of my 78 750k have been significantly drilled.  They were actually an ebay score from years ago but they have been in service for over 3 years and work quite well with solid braking performance.  They reduce the weight of each rotor by about 1/3 . . . .
Those look very nice! As does what can be seen of your bike!
Another additional approach would be to have them thinned as well, knocking off as much as another 30% (from original weight). Less unsprung weight improves braking and overall traction.
Offline eengler2
    • Online Album
« Reply #245 on: August 03, 2008, 08:38:35 PM »
Less un-sprung weight improves steering/handling, not necessarily braking. I would imagine, on the single rotor front ends, thinning would surely result in warping the rotor when trying to stop these behemoths repeatedly without cool down.
1975 CB750: 4-1, mini tach/speedo, vintage Guillari seat, Raask rearsets, clubmans
2005 Kawazaki Z1000: Sold
2003 Buell XB9S: Sold
1998 Buell M2 Cyclone: Sold
1978 CB750: Given back to my father
« Reply #246 on: August 03, 2008, 09:04:32 PM »
Indirectly improves braking through better wheel control and traction, especially on rough surfaces.
http://en.wikipedia.org/wiki/Unsprung_weight
Single rotor perhaps though I would doubt it. The disc is much thicker than it needs to be. Mine is a dual disc admittedly. I had them thinned to the legal limit in 1975, influenced by an article at the time interviewing Yoshimura I think.  I road raced for several seasons, drilled many holes in them and then put at least 50k on the street. Plan to use them again on current project. I am talking about a K2. You made me look and all my newer bikes have thinner discs than a stock K2. But my 76F appears to have very thin discs as well.
The rotors in question (a 76 or later GL1000) may already be thinner, if so never mind. But the early Ks are too thick IMO.
But its a question for each to answer for themselves.
Offline Accolay
Rotor Drilling Service
« Reply #247 on: August 23, 2008, 10:46:30 PM »
Has anyone used this guy off Ebay?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=160272391778&indexUR
L=0&photoDisplayType=2#ebayphotohosting
I'm concerned about getting someone who knows what they are doing. Don't want it over drilled and weakened.
1977 CB550F
fuzzybutt
Re: Rotor Drilling Service
« Reply #248 on: August 24, 2008, 12:57:20 AM »
i've seen too many rotors crack between holes. i think i'd much rather have a slotted rotor that drilled and not the slots all thw way through, theyre more like grooves. i ran powerslotted rotors in a mustang lx i used to have and they did make a difference when hauling down from 120 mph+
« Reply #249 on: August 24, 2008, 03:09:51 AM »
Those discs look pretty good, there was another guy on EBay who also "surface ground" the discs to ensure no warping and an excellent braking surface, but I think he was a bit more expensive.
The old SOHC4 discs are so thick and heavy, drilling them is a great way to reduce unsprung weight and disc heat, and improve your bike's braking performance.
I did my own, but it was a shiite of a job, even using cobalt drill bits at super slow speed I destroyed two drill bits and had to sharpen them every couple of holes, so I'd be happy to pay 60 bucks a disc for a good job. Cheers, Terry. ;D
