Author Topic: Swing Arm Test?  (Read 1985 times)
Offline wedoo2
Swing Arm Test?
« on: November 26, 2011, 03:09:23 PM »
Working on my 74 550 restoration and I was wondering if there was a way to tell if the swing arm needs a refurb as well.  The arm moves up and down freely without any noticeable hitches.  It does not move completely free, more like it is on there tight.  I think ok.  What say you?
Some days the sun is too loud.
Offline FuZZie
Re: Swing Arm Test?
« Reply #1 on: November 26, 2011, 03:11:45 PM »
have you checked sideways or for any possible wobble?
Offline d9canada
Re: Swing Arm Test?
« Reply #2 on: November 26, 2011, 04:01:10 PM »
According to the FSM, the bushing ID should be between 21.44 mm (new) to 21.8 mm (service limit) page 139 and the measurement process is shown on page 82.
If your bike has less than 30,000 miles, it is likely to be OK.  But I would suggest removing the pivot bolt, clean everything, check bolt & swing arm bushings for excessive wear.  Reassemble with appropriate lube as per FSM.  New bushings are pretty inexpensive at partsnmore.com, I just happened to see them the other day, though I am not sure which years they have in stock.  Make sure you can get replacements for your year/model before removing your old bushings.
« Last Edit: November 26, 2011, 04:06:44 PM by d9canada »
Brian
CB350F to CB900C
GL500
GL1000
CBX
02 Sportster 883
64 Suzuki M15D Sovereign 50cc
Offline camelman
  • Man... Myth... Legend
Re: Swing Arm Test?
« Reply #3 on: November 26, 2011, 11:47:51 PM »
Push the swingarm side to side.  That is where you will find evidence of wear.  If there is any shifting at all, then you will notice it when riding.
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline onepieceatatime
Re: Swing Arm Test?
« Reply #4 on: November 27, 2011, 04:10:47 AM »
I didn't know that sentient pasta gave motorcycle information.  ;D
http://en.wikipedia.org/wiki/Flying_Spaghetti_Monster
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline CBDee
Re: Swing Arm Test?
« Reply #5 on: November 27, 2011, 07:28:16 AM »
What is a FSM? F***ing Shop Manual?I want a copy. Side to side on the centerstand is the way to measure. also if it's ridable, watch the swing arm when you shift and accellerate, you'll see the sw move if theirs a problem. it's how i knew mine needed some attention.
Flying Sphagetti Monster,,, i like it!
Sent from my Old & Busted PC using Myindexfingers
Re: Swing Arm Test?
« Reply #6 on: November 27, 2011, 09:37:01 AM »
FSM= Factory Shop Manual
Offline Rgconner
Re: Swing Arm Test?
« Reply #7 on: December 08, 2011, 03:18:18 PM »
More people believe the FSM than in  the manual.
1975 CB550K aka "Grease Monkey"
