Author Topic: CB125s compression issue  (Read 11306 times)
Offline y2kc0wb0y
  • B00msh0cka
  • Shoot the pickle....
Re: CB125s compression issue
« Reply #25 on: May 04, 2012, 09:15:23 AM »
Got the bike back together and running. Question: are the CB125 engines on the noisy side normally???
CB750K3 890cc| 2004 VFR800A| 76 CB550F| 77 CB750F| 73 CB350G| 79 XLH| 2007 BMW R1200GS| CB750K2
Offline grcamna2
« Reply #26 on: May 04, 2012, 10:04:42 AM »
Can you give us any details about the top end work that you did to it ?
75' CB400F/'bunch o' parts'
Offline y2kc0wb0y
  • B00msh0cka
« Reply #27 on: May 04, 2012, 10:51:29 AM »
In addition to replacing the piston and honing the cylinder we did just "basic" valve work seeing the bike only has 600 miles on it. Meaning: We just pulled the two valves, polished, lapped, cleaned the squish/combustion area of carbon and re-assembled per the manual.
Offline grcamna2
« Reply #28 on: May 04, 2012, 12:51:33 PM »
How did your cylinder measure up? did you use an inside micrometer that gave you accurate measurements all the way up & down the bore of your cylinder ?
Offline y2kc0wb0y
  • B00msh0cka
« Reply #29 on: May 04, 2012, 04:27:30 PM »
Didn't have a meter. Used the compression ring and measured the gap which in ec down the sleeve
Offline Flying J
« Reply #30 on: May 04, 2012, 04:58:36 PM »
What noise its it making? I rebuilt my 125 and i would not say that it is a quiet motor.
Offline grcamna2
« Reply #31 on: May 04, 2012, 06:28:40 PM »
Roasted; I wonder what the back story is on this damage. I was able to hone the cylinder wall out so just a finger nails size nick was in the wall. Do you guys think I'll generate a large heat spot here if I leave the nick? The rest of the cylinder looks good.
It's possible the cylinder sleeve could be warped or out-of -round from too much heat in one place and that's causing it to be tight at one point in the stroke of the piston and loose at another point..localized overheating.
Offline y2kc0wb0y
  • B00msh0cka
« Reply #32 on: May 05, 2012, 07:36:44 PM »
Sounds is hard to describe - rattling and a lot of carb roar.
