Author Topic: Head removal tools  (Read 1298 times)
Offline buffaloejon
Head removal tools
« on: November 30, 2011, 10:19:05 AM »
Alright guys, I apologize in advance for asking simple and stupid questions... That I'm sure if I dug through search results for hours I might find, but...
What tools should I need for taking the head off, anything special aside from valve spring compressor and sockets/wrenches?
I just want to make sure I have everything I'll need this weekend when I dig into the head. I've got a couple guys coming to help me that know a heck of a lot about engines, but not about these old gals specifically, so I want to make sure we don't get stuck and then I'm just wasting their time...
What I'm worried about in the shop manual is step 9 in section 3-3 (pg 34) of the CB750 shop manual, where it says "Remove the cylinder". I would assume it means the head, right? I'm not 100% about what to do here... I'm sure I'll end up fine with these guys helping, but I want to make sure there's nothing special to do.
I know I need a haynes or something, but I'm counting on getting HM's book for christmas... And anyway, I don't have time to get it before this weekend.
PS, I know to look for hidden bolts and such, seen enough posts about that!
Engineers like to solve problems. If there are no problems handily available, they will create their own problems.
76 CB750K
http://photobucket.com/buffaloejon
Re: Head removal tools
« Reply #1 on: November 30, 2011, 12:49:04 PM »
What not tell us what your intent is? That would help us give you more precise answers.
You don't have to remove the cylinders to remove the head but you'll probably/may want to replace the cylinder base gasket as it's sealing ability may/will be compromised. If this is the case then yes, you will need to remove the cylinders. That takes no additional tools. You do need to remove the cam however because the of cam chain holding the cam which prevents the head from coming off. That'll be the seemingly trickier thing here. Loosen the cam chain adjuster and valve adjusters. Remove the rocker shafts and rocker arms. Remove the caps that hold the cam. Make sure you keep all these parts in the correct place/order as they are matched to position! Take the 2 bolts out of the sprocket before you do the other stuff while it's still held in place and slide the sprocket off it's mounting point on the cam then thread the cam out from the cam chain. A socket or 2 and a wrench is all you need. May need a rubber mallet or similar to bump the head if it's stuck to the cylinders or the cylinders are stuck to the case. Valve spring compressor is not necessary to just remove the head vs taking the head apart. Hope I remembered the correct order. Easy to do, be patient and refer to your manual ALONG WITH those "experienced" friends that haven't done a 750 before. First time may take half the day. Next time 15 - 30 minutes.
« Last Edit: November 30, 2011, 12:50:37 PM by Jerry Rxman Griffin »
Offline buffaloejon
« Reply #2 on: November 30, 2011, 01:08:51 PM »
My intent is to repair a stripped thread in #3, and go ahead and helicoil 2 and 3 at the same time, to ensure it never happens again...
Thanks for your reply, I ordered a full gasket set from Athena, I've heard its missing a few things, any idea on what else to order?
76 CB750K
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #3 on: December 02, 2011, 09:02:37 AM »
A basic metric socket set, metric open end/ box wrench set, needlenose pliers set, screw driver set, and don't forget a philip drive impact screw driver. get a complete top end gasket set. Possibly a 6mm helicoil set (exhaust studs have a tendancy to pull out on these old bikes if the engine has been over heated). You should be good to go.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline grcamna2
« Reply #4 on: December 02, 2011, 06:50:28 PM »
As far as helicoils  go.....I like a product called Timesert which is a solid threaded insert;it's sold in a kit.
