Author Topic: Can I improve my CB400F w/ CB750 front brakes ?  (Read 5821 times)
Offline grcamna2
Re: Can I improve my CB400F w/ CB750 front brakes ?
« Reply #25 on: December 04, 2011, 02:03:02 PM »
I just had a look on Feebay and those Katana front MC's are mainly for clubman or clip on style bars that are curved down;if I were to install them on flat bars they would look tilted.I have my flat bars. I have been looking at this pic that Psychonaut posted on here w/ the XR MC and it looks like it will work...I just hope it pushes enough volume for my 1) 38mm caliper piston.
Offline veloracermike
« Reply #26 on: December 04, 2011, 02:13:41 PM »
Yeah mine are clip ons.
« Reply #27 on: December 04, 2011, 02:25:43 PM »
The cb550 has a single 38 mm piston caliper and it uses a 14mm master cylinder. Not great brake perf in stock form.
Many of the bikes w/external reserviors are mounted on a bracket...so, you could adjust the angle of that bracket to allow it to deal with the std handlebars.
Otherwise, you need to consider other makes of mc when looking.
Also, consider that some of the supposed "Brembo" mc on ebay are counterfeit. So, buyer be ware!
Offline grcamna2
« Reply #28 on: December 04, 2011, 02:53:16 PM »
Thanks Dave...I'm looking for a good choice of MC;what would you choose ? I like to have more "push" & I think a smaller bore MC might accomplish that.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #29 on: December 04, 2011, 02:58:59 PM »
GR,
I didn't have a chance to make it out to the garage to hunt up 550 front brake parts.  After reading the past few posts, it sounds like your design is still in a bit of flux.  Hope I'm not delaying your project.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline crazypj
  • I'm brill, me
« Reply #30 on: December 04, 2011, 03:58:53 PM »
I'm running an 11mm master cyl on CB360 (same brake as 400f)
I don't have pads bedded in properly yet (only done a few hundred miles)
Brake is a bit spongy at present but I think caliper is twisting slightly?
I'll probably remove pads and file down high spots to get it working better)
It seems to move plenty of fluid
Offline grcamna2
« Reply #31 on: December 04, 2011, 05:47:41 PM »
Old School,
     I appreciate your feedback and I am sure that I want your O.E. CB550 front rotor/disc if you'll sell it to me, I Know it will improve my braking performance.I am in the process of planning & have a good plan of action going, take as much time as you need;I know you have other things going on too.
crazypj,
             You're a good dude man!...I needed that confirmation from you that the 11mm MC will work for me(you ever watch "The A Team" back in the day?... "I love it when a plan comes together"!!) and I look forward to completely getting my bike's brakes as good as I can afford.I want to have good suspension and good brakes;lots of different folks out there behind the wheel of "killer" 2 ton 4 wheeled machines...and I want to keep out a' there path of travel...if you know what I mean!! I think HorsePower is excellent...but to me, Stopping & Handling are even better.
                              Thanks folks  this sohc4 forum is Awesome+ w/ Great feedback !
« Last Edit: December 04, 2011, 05:53:44 PM by grcamna2 »
Offline Psychonaut
« Reply #32 on: December 05, 2011, 03:41:48 PM »
grcamna2, I found a few threads with KLR's. They have a single 38mm caliper and a 1/2" master (12.7mm). They think there brakes are wooden, LOL, they should try a 14mm. Anyway they are below if you want to read what they had to say.
http://www.thumpertalk.com/forum/archive/index.php/t-733815.html
http://www.advrider.com/forums/showthread.php?t=666336
There's a few Triumphs with 11mm masters too. Some have 1" bars. The Thunderbird sport is larger than 11mm.
http://www.triumphrat.net/hinckley-classic-triples/190284-which-front-brake-master-cylinder-for-900-thunderbird.html
7/8 bar list
http://www.biker-discount.co.uk/legend-tt-900-handle-bar-risers-30mm-for-triumph-78-22mm-bars-black-or-alloy-2072-p.asp
Offline grcamna2
« Reply #33 on: December 05, 2011, 03:50:01 PM »
I was looking on Feebay & noticed a front MC for a 1995' XR650L...do you think that would be a good choice ? I can't find any specs on it...but it could be an 11mm.
Offline grcamna2
« Reply #34 on: December 06, 2011, 04:23:06 AM »
Yeah, it seems that 95' XR650L MC is what I'll go for when I can find a good one.
Offline grcamna2
« Reply #35 on: December 15, 2011, 05:03:39 PM »
Has anyone tried fitting a different Honda caliper ? or how about improving the O.E. caliper & pads to grip better ?
« Reply #36 on: December 15, 2011, 05:20:50 PM »
From mwy searches and reading the only choice you have is to go to dual discs, keep your pads and rotors deglazed as routine mtce and use good quality EBC pads. Drilling the rotors helps in wet conditions and some believe also in dry.  Otherwise, you are looking at different forks or custom brackets for other calipers; if you can find any that fit in limited space and would work with stock rotors.
You have to accept them for what they are and drive accordingly or spend the money and time to improve them. There are no cheap quick fixes.  Question becomes is your life worth the extra $$??
Offline grcamna2
« Reply #37 on: December 15, 2011, 06:24:30 PM »
Thanks RAF
Offline grcamna2
« Reply #38 on: December 19, 2011, 07:19:43 PM »
Is it possible to adapt a more powerful caliper to my CB400F? or am I stuck w/ O.E. ?? also wondered if anyone tried to put a stock(33mm)size right fork tube on to mount dual calipers ?
Offline Psychonaut
« Reply #39 on: December 20, 2011, 04:42:44 AM »
You could do with a larger bore caliper but it would be easier to do the smaller master. I bought a 11mm master on Ebay last week.  I'll let you know how it goes when it comes. If it is too much brake I'll try a 1/2".   I saw that XS650's use 35mm forks. You can use a 550 triple. They make larger brake kits for those bikes. http://650central.com/
Offline crazypj
  • I'm brill, me
« Reply #40 on: December 20, 2011, 06:34:13 AM »
You can't have too much brake  ;)
It's just learning to use it
I fitted early Suzuki Katana calipers (pre 98) to my XS (4 pot instead of 2 on slider)
You can also get emulators 'cheap' from Mikes XS is you use 650 Yam forks with 500/550/750 yokes
I've also fitted early CX500 forks (33mm) into 400f to use dual disc
« Last Edit: December 20, 2011, 06:40:05 AM by crazypj »
Offline Psychonaut
« Reply #41 on: December 20, 2011, 01:07:18 PM »
True, I should have said too much lever pressure or too sensitive. There is a sweet spot and that's what I'm looking for.
Offline grcamna2
« Reply #42 on: December 20, 2011, 01:15:12 PM »
crazypj,
      You said early CX500 are 33mm?? will they run dual calipers,one for each side ?
Offline crazypj
  • I'm brill, me
« Reply #43 on: December 20, 2011, 09:27:53 PM »
sliding calipers, one each side behind fork leg.
 May be difficult to find a decent set, thye will be pretty old by now.
 CB400 twin used same forks, the 'Eurosport' had dual disc IIRC?
