Author Topic: disc brake drill templates  (Read 2666 times)
Offline charlie27
« on: December 01, 2011, 01:59:35 PM »
hi,
looking for swept holes pattern in pdf file that will print to scale to use as a template.  search attempts have not yielded any results.
thanks for the help
Re: disc brake drill templates
« Reply #1 on: December 02, 2011, 09:08:45 AM »
« Reply #2 on: December 02, 2011, 09:17:19 AM »
I had to print two pages and over lap them to get a full pattern. Quality drill bits and proper lube/coolant are essential. I ruined a bit early, changed lube and did all the rest of two rotors with the same bit. Carefully tape the pattern over the rotor and centerpunch the holes. If you are doing two for a dual disc, index them to the hub so the holes on both rotors will line up when finished. I did the first one then put the bolts through both hubs and transfered the holes with a transfer punch. Either de-burr the holes with a stone or turn them. I didn't chamfer the holes, there are arguments for and against.
« Reply #3 on: December 02, 2011, 09:18:20 AM »
Oh yeah, gloves and glasses. The cuttings are sharp.
Offline charlie27
« Reply #4 on: December 02, 2011, 03:14:38 PM »
thanks!!  that will work
Offline 750K
« Reply #5 on: December 04, 2011, 12:49:07 AM »
Thanks for the link, I've been wanting to drill my front rotor.
77 Cb750, 78 Kz1000
