Author Topic: Hand Controls  (Read 964 times)
Offline gccycles
Hand Controls
« on: December 05, 2011, 07:10:48 AM »
So I think I am going to finally put an end to all my quick fixes and rewire my bike this winter.  Something I really need to do is replace my worn and non functional hand controls.  Where can I find these things?  I have a 73 cb 750 and as you all know the hand levers and electric control are all 1 piece.  Will trying to find replacements be a hopeless journey?  I mean of all the guys out there rehabbing this model what are the options.  The biggest obstacle is the throttle is a push/pull setup and there is not getting around this.  Does anyone have advice on what they would do if they were doing a build up and could not salvage the original forward hand controls.  Thanks in advance.
Offline Rigid
  • She likes a
    • KingCustomCycles
Re: Hand Controls
« Reply #1 on: December 05, 2011, 07:17:13 AM »
Your options are nice original controls, either new or used.  OR, you can move the electrical functions elsewhere and use "chopper" style clutch perches, master cylinders, and throttle assemblies.  The back of the headlight works well for basic electrical switch controls.  You can use pull only, a large spring at the carb returns it, usually.
« Last Edit: December 05, 2011, 07:25:28 AM by Rigid »
Re: Hand Controls
« Reply #2 on: December 05, 2011, 07:22:57 AM »
I adapted R6 controls from year 2005?  I think  and they work well. Even with the original throttle (mine is pull only) but the control has holes for push/pull.
Check them out on ebay, they look good too. The light switch is LH and only High/Low but I dont mind the light on all the time for safety.
Offline Trav-i
  • Has finally become an
Re: Hand Controls
« Reply #3 on: December 05, 2011, 12:40:24 PM »
Motion Pro and Emgo both make a push/pull throttle only to fit our bikes, meaning it has not hing else with it.  Check out Pingle for the actual electrical switches, they have some pretty cool stuff.
Forum member #9962
1992 GL1500 Interstate
Offline gccycles
Re: Hand Controls
« Reply #4 on: December 15, 2011, 04:01:03 PM »
Many thanks.  I will start checking into your suggestions.
Offline mrbreeze
  • Not your average
Re: Hand Controls
« Reply #5 on: December 15, 2011, 04:51:59 PM »
I run Yami 650 controls that I got from Mike's XS. They cost $60 each. They have all the functions that our OEM's have. They are pull cable only though and you have to use a Yami  cable. If you end up going that route...........I can give you the wiring instructions to convert to your bike.
MEMBER # 257
Offline gccycles
Re: Hand Controls
« Reply #6 on: December 21, 2011, 03:18:46 PM »
So if I end up going the pull only route I can just go with a heavier return spring?
Offline luap
  • LAWL
Re: Hand Controls
« Reply #7 on: December 21, 2011, 03:35:21 PM »
the motion pro throttle housing has both push an pull so you can run the return cable also
http://www.motionpro.com/motorcycle/partno/01-0058/
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
