Author Topic: Weird starter noise (video)  (Read 1122 times)
Offline dr.seiss
« on: December 06, 2011, 10:40:17 pm »
Can anyone tell me what might be causing this noise?
12 04 11 115
Also, here's a vid of the bike running.
12 04 11 120
Offline Rigid
  • She likes a
    • KingCustomCycles
Re: Weird starter noise (video)
« Reply #1 on: December 07, 2011, 02:24:56 am »
Starter clutch damaged.
Offline dr.seiss
« Reply #2 on: December 07, 2011, 11:51:41 am »
Thanks guys. Is damage to the starter clutch something that can be repaired or will I have to replace it?
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #3 on: December 07, 2011, 12:16:00 pm »
Usually it will need replaced.  I have seen the rollers crack and chip and the springs fail.  The housing will distort also causing unreliable operation.  Best bet is a used one off eBay, they aren't a common failure so their is a supply of good used ones.  Disassemble first, sludge can stick the rollers also and then you just need a cleaning.
Offline richvageologist
« Reply #4 on: December 07, 2011, 12:47:33 pm »
This may be a long shot but is sounds like you are going to want to take the alternator cover off anyway.
I had the starter gear (part #1) strip four of the small teeth off of the gear on my '75.
It would not happen all the time but it would make a similar noise to what you are noticing when you let off the starter button.  I replaced that gear with one off of a spare motor I had sitting around it is hasn't given me a problem since.
While you have the cover off, check to make sure all the gears associated with the starter still have all of their teeth.
'73, '74, '75, & '77 CB750Ks
'00 Victory V92C (Don't tell it that it is supposed to have transmission issues)
Offline dr.seiss
« Reply #5 on: December 07, 2011, 05:27:23 pm »
Thanks for the help guys!
