Author Topic: Sorcerer and Atchison, Topeka and Santa Fe to be restored  (Read 493473 times)
Offline RP
    • Restoration Paint
Re: Sorcerer and Atchison, Topeka and Santa Fe to be restored
« Reply #2750 on: March 26, 2016, 06:07:34 AM »
Nope, first time!  ???  :-\
The sad part about this project is the tooling designed and machined ( BIG $ $ $ ) to get this right will probably never be used again.  :(  :(  :(
I MIGHT be a bit ANAL/OCD as brother Mike reminded me recently that he was absolutely positive that Russ, Byron, and company went about the originals just as meticulously - sure thing!  ;D
I doubt Russ and Byron did any serious machine work on the hubs and brake discs,  they were most likely sourced from Kosman, or some other wheel specialist back then, like the components on the bike in the photos from the first test run most likely were.
Ralph
www.paintworkz.com
78 Z1R TC
84 Ninja 900
CBX Pro Stockers
CB750 Funnybike
77 KZ1000 tubo
Offline kmb69
« Reply #2751 on: March 26, 2016, 08:15:43 AM »
Ralph, I bet you are 100% correct on that. Did not occur to me but, that was part of the business Kosman and such were in, they were tooled up, and did it every day.
Offline gschuld
« Reply #2752 on: March 26, 2016, 08:33:06 AM »
RC was extensively using custom Kosman stuff since at least the 3 RC in house built double engine dragsters they built in late 1972 through early 1973.  Multiple mentions in 1973 articles I have.  Same for the triple built soon after I'm sure.
I could look for documentation if it matters.
George
« Reply #2753 on: March 26, 2016, 09:03:32 AM »
I was wondering about the 6 bolt pattern, a lot of drag hubs are 8 bolt , but the 6 bolt are probably bigger bolts.?
Offline kmb69
« Reply #2754 on: March 26, 2016, 10:41:13 AM »
The original pattern was 8 - 5/16" holes on a 3" bolt circle.
They are 12mm, shouldered, grade 12.9 studs, on a 4.5" bolt circle going in the sprocket side. Should be good. I hope it's good.  :)
Room to add 6 more on that 4.5" BC if necessary.  ???
« Last Edit: March 26, 2016, 10:55:47 AM by kmb69 »
Offline kmb69
« Reply #2755 on: March 26, 2016, 11:21:28 AM »
Frank, don't make me be second guessing myself!  ???  ;)  8)
The picture below is Hawaya Racing's current offering for their Top Fuel Harleys running 12", maybe even 14" wide slicks.
I think Russ' tire is 8" or 9" wide.
Offline Old Scrambler
« Reply #2756 on: March 26, 2016, 06:56:51 PM »
'shouldered' is good..............if the sprocket is riding on threads...........NO GOOD ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #2757 on: March 26, 2016, 08:36:58 PM »
IIRC, big-block Mopars used a 5 on 4.5" BC? The BC should be OK. How deep are the studs threaded into the hub? Should be at least 24mm, preferably more.
Offline dusterdude
« Reply #2758 on: March 27, 2016, 06:35:44 AM »
You remember correctly
Sent from my LG-D850 using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline kmb69
« Reply #2759 on: March 27, 2016, 07:39:23 AM »
The sprocket studs are M12x1.25 on both ends like Honda. There is a .500" (12.7mm) close fit counterbore for the shoulder and 1.05" (26.7mm) thread below that. Should be good - no?
The shoulder on the stud extends out the full .375" width of the sprocket. Uses a lock washer and nut on top so the threads in the hub don't get worn out.
I planned to put blue Loctitite on the studs in the hub at final assembly. It should secure them pretty good and not destroy the hub threads like red if removal is necessary.
The studs for the disc are designed similarly, shouldered, and are overkill at M10x1.25 on a 2.75" BC. All of the studs, sprocket, disc, and wheel are high strength Unbrako.
The wheel studs are 9/16"-18 on a 4.75", Chevy, bolt pattern. They are not shouldered since the wheel centers on the hub and the lug nuts. They do bottom out in the hub.
Scottly are you an Engineer?
« Last Edit: March 27, 2016, 07:42:54 AM by kmb69 »
Offline gschuld
« Reply #2760 on: March 27, 2016, 08:01:24 AM »
Happy Easter Russ.
George
Offline kmb69
« Reply #2761 on: March 27, 2016, 08:01:45 AM »
Both the Vantine and Sparta Top Fuel bikes use 6 stud/bolt sprocket hubs.
Offline kmb69
« Reply #2762 on: March 27, 2016, 08:43:05 AM »
IMG_0795sm.jpg - The wheel had to be "reverse" mounted.
Was first mounted "frontards", the cast face skimmed to be parallel with the "backards". Then new lug bolt holes were machined from the back side 36 degrees out.
IMG_0510sm.jpg - Sammy in one of his favorite situations!
« Last Edit: March 27, 2016, 08:47:25 AM by kmb69 »
« Reply #2763 on: March 27, 2016, 08:47:29 AM »
I dont think the 6 stud is weak as long as the studs are at least 3/8.
In the beginning of this, they were trying to be close to original, but when the old style discs prooved hard to find, theiy. Decided to use other parts..
 The triple went thru several versions anyway, this is I think is version 4..
Offline kmb69
« Reply #2764 on: March 27, 2016, 08:53:57 AM »
Yes, we could not find good enough pictures of the last version to replicate.
So we be improvising as best we know how. The studs are 12mm, so they are 26% bigger than 3/8".
« Reply #2765 on: March 27, 2016, 09:25:03 AM »
Sammy...........the 'shouldered' stud-muffin
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #2766 on: March 27, 2016, 09:30:58 AM »
a maddafawkn P I M P!
...Save a tree, eat a beaver...
Offline slikwilli420
  • Master of Disaster
« Reply #2767 on: March 27, 2016, 09:56:39 AM »
Happy Easter Russ.
George
The left handlebar soars to have a hydraulic master cylinder. Is there a honda that had a hydraulic clutch that used a master cylinder that matched the brake unit?
Offline dusterdude
« Reply #2768 on: March 27, 2016, 01:09:56 PM »
Some old farts have all the fun
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline gschuld
« Reply #2769 on: March 27, 2016, 01:31:11 PM »
My apologies if this has already been posted, I can't remember all 111 pages...
But it's good stuff...
George
Offline gschuld
« Reply #2770 on: March 27, 2016, 01:39:00 PM »
More
Offline gschuld
« Reply #2771 on: March 27, 2016, 01:42:35 PM »
Last one.
Offline gschuld
« Reply #2772 on: March 27, 2016, 01:43:32 PM »
Nice ad.
George
« Reply #2773 on: March 27, 2016, 04:22:23 PM »
Nice ad.
George
I want that last one on a shirt.... ;)
Offline gschuld
« Reply #2774 on: March 27, 2016, 05:45:28 PM »
That could be done....but it would need an OK from Russ Jr.
George
